Old 11-27-2011
tominny is on a distinguished road
epoxy for sealing core - recommendations?
I am planning to rebed all deck hardware on my Tartan 34C and in the process want to seal off the balsa core to prevent any future water intrusion. Epoxy seems to be the right product for this. Does anyone have specific recommendations for a brand?
Thanks!
Old 11-27-2011
I'm based in NYC and would like to do this before the spring haul-out. What is the lowest temperature at which this can be done? Are there any special low-temp products that would be appropriate for this job?
Old 11-27-2011
Minnewaska will become famous soon enough
West System makes everything you both need, including an accelerator for cold weather.
Jeanneau 54DS
Old 11-27-2011
teddier1 is on a distinguished road
I had some water in my rudder and the West System and the instructions were very easy to follow. It was my first time working with the material and I highly recommend it.
Good luck.
Old 11-27-2011
mitiempo's Avatar
I use West, but it depends how cold. 40 degrees is about the lowest and 50 is better.
Used to be one called ColdCure - they were purchased by System 3, but I haven't used it for 20 years and forget the temp range. It may still be available.
Here's a good link that show how to re-bed deck fittings step by step.
Re-Bedding Deck Hardware Photo Gallery by Compass Marine at pbase.com
Brian
Old 11-27-2011
Thanks for the great advice!
Old 11-28-2011
nickmerc's Avatar
nickmerc is on a distinguished road
Take a look as MAS epoxies as well. I know they have a variety of hardeners for various temp ranges.
Nick
S/V Blue Bayou
1974 Pearson 30 #517
Old 11-28-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
I have had good results potting holes with West's Six-10.
It is a little more expensive per volume unit, but more than makes up for that in terms of convenience, and because it is extremely viscous (it STAYS where you put it!).
If I were real anal about it, I would mix up some MAS Low Viscosity epoxy with MAS Fast catalyst. Using a syringe, I would inject the Low VIS/Fast epoxy into each hole, so as to wet out all the crevices. Then, again with the syringe, suck it out, and let it set. Then, I would follow up with Six-10.
In practice, however, I have simply used Six-10.
Old 11-28-2011
tommays's Avatar
I used 10 gallons of MAS refitting Seafever and as a BIG MAS fan just used some FAST on a 50 degree day and it was NOT all that fast and i am NOT sure how long it would have taken without the heat lamp
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-29-2011
Irrationally Exuberant
arf145 is on a distinguished road
I've been using MAS to pot the bolt holes on my deck, mostly using their medium hardener. I inject into the holes with a syringe, then suck it back out, mix in silica to strengthen and thicken the mixture and then re-inject.
arf145
1987 Pearson 28-2
Chesapeake Bay
Sealing The Deck Core From Moisture (how to) Maine Sail Gear & Maintenance 23 04-14-2010 10:11 AM
Injecting epoxy in wet core Guidera48 Gear & Maintenance 12 08-03-2009 01:05 PM
Question for Maine Sail - Sealing the Deck Core TejasSailer Gear & Maintenance 5 03-18-2009 10:14 PM
Epoxy mahogany core bg9208 Sailboat Design and Construction 6 11-04-2008 12:21 PM
Sealing Deck Hardware, and Epoxy over Teak 1970Columbia34 Gear & Maintenance 3 08-24-2006 03:34 PM
