Lowering mast has gouged a whole in Deck - Page 2 - SailNet Community
post #11 of 19 Old 11-27-2011
Tartan 27' owner
CalebD's Avatar
This is a random picture of a boom bail: Bail, Vang, Boom
They are often used for the mast base of a boom vang as well as on the boom.
Your idea of using a dessicant for drying the repair area sounds fine. A heat gun might help speed up the process too.
Everybody has one:
CalebD is offline
post #12 of 19 Old 11-27-2011 Thread Starter
GalileoX's Avatar
Thanks. I think this what I will do.
GalileoX is offline
post #13 of 19 Old 11-27-2011
Originally Posted by GalileoX View Post
If I decide to go with the bail I will cut the tab off.
FWIW I think the tang fitting you have now is better and stronger than a bail. The vang can put some extreme forces on the attachment and I've seen bails literally 'tear out' in extreme conditions.
Since you have the deck damage to deal with anyway the deck plate is likely the simplest, least costly approach.
Faster is offline
post #14 of 19 Old 11-27-2011
fallard's Avatar
The deck plate idea is probably an easier and more elegant fix. You have to fix your deck anyway, so why not install something bigger than 2" (more "wiggle" room), like the Beckson deck plate shown at Deck Plate / Inspection Port. The downside is that you would need to borrow a 4 1/2" hole saw, but you could install it temporarily (use tape to get a waterproof seal) and let the plywood dry out. You might then seal the cut edge of the plywood with a low viscosity epoxy and caulk the plate for a permanent installation.
Should you forget to remove the plate and crack it, you would simply buy a new one.
P.S. I have no connection with Beckson or Defender.
fallard is offline
post #15 of 19 Old 11-27-2011 Thread Starter
GalileoX's Avatar
Hmmm...Both very good ideas. I will have to ponder this for a moment but at least I have some options. Thanks everyone.
GalileoX is offline
post #16 of 19 Old 11-27-2011
You should consider how much boring that big hole would weaken the deck right beside the mast step. If this could be a problem, perhaps you could modify the mast step by lengthening the plate at the bottom of the mast a bit, as well as the piece bolted to the deck. IOW, make the hinge a little longer so there will be no contact. Easy to spend someone else's money!
I remove water from wood with a little douse of denatured alcohol. Seems to, anyway.
ggray is offline
post #17 of 19 Old 11-28-2011
..........huh?..
Izzy1414's Avatar
Just wait awhile, G, you'll probably get a few more good suggestions to add to your options. Then you can weigh each one and decide which is best for you. BTW, the bails I have on my boom and mast are like the ones pictured in Caleb's link. As Faster points out, the vang can exert a lot of pressure ... the one on my mast has deformed somewhat (but not failed). I have another bail on my boom for my mid boom mainsheet that is more stoutly built. I think you could probably find a sufficiently strong bail if that is the route you choose to take.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Izzy1414 is offline
post #18 of 19 Old 11-28-2011
JimsCAL's Avatar
Best fix is to remove the rotted wood core rather than trying to dry it out. Even though the deck isn't "soft", there is a good chance water has spread into the deck core, especially since its plywood. Fix it correctly now before it gets worse.
JimsCAL is offline
post #19 of 19 Old 11-28-2011 Thread Starter
GalileoX's Avatar
I don't know? I have no idea how to do that, cut out the wood . What is it replaced with? More wood? How do you replace it? How is the filler that goes in it's place structurally attached to what is already there? The rest of the coach roof that is. All this trouble from one little damned hole.
Why oh why didn't the PO do something better than silicone caulk. Aaarrgh!
GalileoX is offline
Tags
deck , dry , repair
Any tips on lowering the mast on an Oday 22? sailguy40 O'Day 5 08-13-2011 08:52 AM
Lowering a deck stepped mast Zephyrzen General Discussion (sailing related) 17 12-21-2010 03:02 PM
mast raising and lowering divicolouis Gear & Maintenance 5 08-08-2003 10:08 PM
Rhodes 22 mast lowering under bridge GeneStory Gear & Maintenance 1 10-20-2001 08:48 PM
Lowering a deck stepped mast. Zephyrzen Gear & Maintenance 2 04-17-2001 03:31 PM
