12-01-2011
This may be useful information, I had the same symptoms but with a diesel.
Morse single lever control, boat in gear went 5k. It also went from neutral @600 rpm to in gear @1000. From 1100 to 1500 it would return to 1000 rpm.
I talked to a lot of people, had two professionals on board to check it out. No one got it, but the most common suggestion was get a new cable.
Eventually I did, and tried to set everything up the way it was, but now the transmission engaged @1200, talk about jack rabbit starts and prop wash in reverse!
I finally determine the entire problem was a poorly adjusted cable. it now goes into gear while the engine idles @600 and we move quietly along about 2.7k.
From 600 to 1000 the engine returns to idle when the throttle is released, great for low speed maneuvering.
From 1000 up I can select any RPM I wish and it stays put.
maybe you have a cable adjustment issue.
