Old 09-26-2003
LuckyinLA is on a distinguished road
Bases for bow pulpit
The bases (four) for my bow pulpit need replacing. I have done a web search and haven''t been able to find such item. Can anyone recommend a source? I surely don''t want to have to replace the entire bow pulpit over this, but from the looks of it I need specail bases and can''t use stanchion bases.
Old 09-26-2003
ASA and PSIA Instructor
If you have a common boat, you might take this question to a Sailnet email group for your manufacturer - perhpas some company still makes/stocks parts.
If you can''t find a source of OEM parts, see Google.com for sources such as which may have something comparable:
http://bosunsupplies.com/Deck_RailFittings.CFM
http://www.stainlessspecialties.com/stainless.htm
If you can''t find parts you need to see a local SS tubing fabricator about having custom parts made. If you don''t have a volume production boat, my bet is you''ll be facing a rude $urpri$e.
Good luck
Old 09-26-2003
Just checked that link to Bosun''s supplies. I had somehow missed that piece of their website. Looks like they will have something that works. Thanks so much!!!
Old 09-26-2003
paulk's Avatar
paulk is on a distinguished road
SeaDog also has an extensive on-line catalogue of very nice SS fittings. You can order through Sailnet once you know what you need.
Old 09-28-2003
z1nonlyone is on a distinguished road
Go to donalmachine.com, they can laser cut any kind of custom stainless parts at a reasonable rate.
Toerail-mounted stanchion bases ChetBridgeman Gear & Maintenance 3 06-17-2009 12:58 PM
I need pulpit straightening in Kemah, TX borzoijay Gear & Maintenance 2 01-11-2005 07:22 PM
Bow Pulpit for Catalina 38 sailnaway Gear & Maintenance 9 12-04-2004 07:45 PM
Boom gallows/ Mast pulpit angiewilson Gear & Maintenance 1 04-04-2004 07:40 AM
Bent Pulpit hamiam Gear & Maintenance 3 07-23-2003 05:35 AM
