Old 11-30-2011
dougshipl's Avatar
dougshipl is on a distinguished road
Dual refer system Frigoboat & Grunert
We're installing a Frigoboat k50, keel cooled,12volt refer and freezer system supported by our house bank batteries. Our current system is a Grunert engine supported system, which works ok but it's a hassle to run engine everyday for a few hrs to maintain cold box temps. We are thinking it may be best to just leave the engine driven Grunert system in place and instal the Frigoboat separately, mounting the Frigoboat evap. plates just below the Grunert evap plates so that we have the old Grunert system as a back up system on lengthy passages, if needed. Has anyone done this? Aside from taking up space and added weight does anyone see an issue with this?
All thoughts appreciated. Thank you.
DS
Old 11-30-2011
celenoglu's Avatar
celenoglu is on a distinguished road
I have seen similiar installations on different boats. The engine driven unit operates at a lower temparature so when then the engine is running, it cools the box a few degrees below the 12V unit and the electrical one does not work. ıf the engine is not running the electrical unit works.
Old 11-30-2011
dougshipl's Avatar
Thanks Celenoglu
Old 11-30-2011
Capt Len is on a distinguished road
If you run the engine driven compessor to a eutectic fluid plate . cold will last for days before the electric one comes on.I draw freezer down to -30 and days later still rock solid. It's called latent heat of phase change or something like that.
Old 12-02-2011
dougshipl's Avatar
Thanks Capt. I was considering leaving the engine supported Grunert cold plate in place and mounting the Frigoboat thin, 10"x40", evap plate right below it...so the systems would be truely independent. The box is about 7sq ft
Refrigeration-Frigoboat Keel Cooled vs. others? T37Chef General Discussion (sailing related) 58 04-07-2012 09:02 AM
Frigoboat Installation stevemac00 Pacific Seacraft 9 10-12-2010 10:07 PM
Frigoboat Refrigeration obelisk Gear & Maintenance 20 04-30-2010 05:48 PM
Installing Dual Batteries and dual battery switch lmddmc Gear & Maintenance 9 01-02-2009 01:51 PM
Grunert refrigeration telekitr Gear & Maintenance 0 10-27-2007 07:35 PM
