12-04-2011
Real flap valves are bronze and NPT which means threaded pipe fittings. They are gravity operated so placement is important.(heeling may open it) . Common exhaust flapper on small vessels is external on the transom Personally, I have trouble with trusting any 100% Proper sea cocks must be on any thruhulls ,flappers are secondary I like an RV type plastic blade valve inboard the exhaust port.They easily fit the existing hose and are push/pull operated.So if you can reach it or the extended handle its good peace of mind. As an aside, I installed a ball valve in the aqualift muffler to insure that any failure of salt water stuff doesn't get to cylinders, Mine works off the key but manual is good if you remember when open and close should occur.
