Code D = Gennaker + Spinnaker - Page 2 - SailNet Community
 1Likes
post #11 of 21 Old 12-20-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by dhays View Post
Yes it is possible. Check this out. I know of one person to have installed one and that was at the end of this last season. It sounds very interesting to me for short-handed cruising.
Goodo ... the ease of gybing the thing has got to be a big plus for us plodders with only a couple on board.
Shame its so close to the holidays, no time to get it done before we take off.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #12 of 21 Old 12-20-2011
jackdale's Avatar
I have had issues with the Code 0 hour-glassing as it it furled. In very light airs this has resolved itself, in heavier winds it was just nasty.
jackdale is offline
post #13 of 21 Old 12-20-2011
tdw
tdw's Avatar
urrkkk .... plus 15 or just plus 10 ?
― Terry Pratchett.
tdw is offline
post #14 of 21 Old 12-20-2011 Thread Starter
Jack, I don't understand what you mean by hour-glassing, but the only trouble I had with the Code 0 was that I could not have it permanently set I mean in the furler. with winds over 20K I would have to take it down (already furled) and I just tie it along the side of the boat.
The problem was that with the wind force the very thin fabric was pulled out and even without unfurl it got more tight and that means that some considerable part of the geenaker come out and start flapping on the wind.
The other problem was not really a problem but a limitation of that sail. It is not really a downwind sail. It cannot take more than 15K wind. When I started to have fun downwind I had to put it down, afraid that it blow away.
post #15 of 21 Old 12-20-2011
I don't discuss my member
zz4gta's Avatar
Code 0 is very different from this sail.
ok, I'll bite. How is this different than a Code 0 that is typically flown from a wire or spectra/dyneema luff? Because it has a slightly wider TWA use? I'm not seeing how this is new or exciting. It's a code 0 that doesn't point as well, and is made from nylon. So you can't point as high as a true code 0, which most people don't have, and it doesn't run as well as an asym kite.
Is it just handling the sail that's the selling point? Why not just buy a reaching headsail? I guess it's nice for cruising boats. I never thought an asym was that hard to handle.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #16 of 21 Old 12-20-2011
jackdale's Avatar
Maybe about 12
jackdale is offline
post #17 of 21 Old 12-20-2011
jackdale's Avatar
Paulo the top and bottom of the sail stayed filled while the centre section furled, giving an hourglass shape. The centre section was so tight we had to bring the whole thing down to fix it. That was under 15 knots - close reaching.
Beam reach to broad wind I had a gennaker. The gennaker was a flat cut and would also close reach maybe 60 degree off the wind.
jackdale is offline
post #18 of 21 Old 12-21-2011
tdw
tdw's Avatar
So question .... if a cruising boat is only going to have one light wind reaching/running headsail ... which is it to be ? I don't care that much about DDW, i find it too stressful, so I usually drop off a few degrees.
― Terry Pratchett.
tdw is offline
post #19 of 21 Old 12-21-2011 Thread Starter
Sounds good to me.
Tell me ... is there any reason an assy could not be used on a furler ? I'm pleading complete ignorance here but I'd love to get the damn thing permanently out on deck.
Jacobno
I see your point but sail stowage , particularly on a cruising boat is a pain. Anything to reduce the number of sails cluttering up below deck is good for me.
Yes it can but the sail has to be modified. The luff has to be much stronger.
This sail is precisely about that, about to have less sails. To sail fast in light winds against the wind you need a geenaker, to run you need a Spinaker or an asymetric spinnaker.
With this new kind of sails you can have the two in one and even have it on an easily deployable furler.
As Doyle says: The Utility Power Sail, UPS, gives cruising sailors the speed and power of a traditional spinnaker and the ability to sail at wind angles as close as 35 degrees.
Of course they are exaggerating a bit, it would not be as efficient as a Code 0 upwind neither as efficient as a spinnaker downwind, but the difference would not be much, in what regards a cruiser's perspective. In fact you will have a sail that can do both things relatively well.
I have sailed many years with a Code 0 and it is an incredible sail upwind till 120/130º tw but I could not run. This sail permits both things and will not collapse like a spinnaker when too near the wind.
I have heard people saying very good things about Code D (Delta voile) and if what they say on the Doyle site by its costumers deserve some credibility, it seems that it is also the case there.
post #20 of 21 Old 12-21-2011
jackdale's Avatar
I would suggest a fairly flat cut gennaker with a slightly shorter luff that can be hardened down to the pulpit. That should cover you from about 60 degrees apparent to about 135 / 150 apparent. You could run with it in flat water, if desired.
jackdale is offline
Using a spinnaker as a gennaker peterchech General Discussion (sailing related) 17 11-15-2011 11:27 AM
gennaker rigging on a C22 rainbowmagic Gear & Maintenance 3 09-28-2009 01:18 PM
Gennaker/reacher Dcneuro General Discussion (sailing related) 3 06-09-2009 12:50 PM
How useful is code zero/gennaker furler? sailbear50 Gear & Maintenance 1 03-23-2008 06:29 AM
Spinnaker/Asymetric/Code 1? Harpooner General Discussion (sailing related) 1 06-12-2001 09:37 AM
