12-07-2011
Wichard mast tangs- 2, one over the other..
Hello,
I am looking at the Wichard 9150 mast tang. This basically gives you an attachment for a block shackle up on the mast.
This tang comes in two "L" shaped pieces that are bolted together to form a "T" shaped piece. The ears of the "T" fit on the INSIDE surface of the mast. You cut a slot and fit both Ls inside and bolt them together. Then you rivet to the mast.
Does anyone forsee a problem with mounting 2 of these on the forward side of the mast one over the other?
thanks,
groundhog
