Old 12-07-2011
tominny is on a distinguished road
Port frame stuck
I am in the process of rebedding my 34 year old portlights and exchanging the plexiglass with Lexan. I was able to remove the outer aluminum frame and the glass, but the inner aluminum frame is stuck and not moving. There are no mechanical fasteners (bolts, etc.), so it is probably the old sealant and the ooze of time that binds it to the cabin.
Does anyone have any suggestions what I can do here? Pour in some acetone perhaps or another chemical so the sealant dissolves...?
Old 12-08-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Try Debond, it works really well
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 12-08-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Can you slide a razor knife (Olfa type - also called box cutters) between the frame and the mounting surface? If you can slice well into the sealant you might break enough of the bond to be able to lift it. At the very least it would help Pappy's method along.
I was able to completely remove the lens from an aluminium hatch this way - just had to clean up the bits of sealant that were left behind.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Fairclough frame for 42 footer Albin Nimbus 42 Gear & Maintenance 0 11-14-2011 04:14 PM
Dodger frame oceangirl Pacific Seacraft 3 02-17-2011 01:12 PM
X-362 Sport - Steel Frame StephenMaturin Boat Review and Purchase Forum 7 01-21-2011 09:08 AM
Split Companionway Frame itsme6582 Gear & Maintenance 21 04-22-2010 04:03 PM
Building a frame for my winter cover Pensker SailNet Website Technical Support 2 10-23-2006 08:36 AM
