Old 12-08-2011
jarcher's Avatar
jarcher is on a distinguished road
Washing Sunbrella cushion covers
After two seasons, I think its time to clean my Sunbrella cushion covers. I checked Sunbrella's web site, and the instructions are that they can be washed in the washing machine using cold water, then air dried. It said use soap but not detergent, which I don't understand. What's soap? Do they mean something like Woolite that says it is for delicate fabrics?
I did see that they said not to dry clean, and not to use hot water or heat to dry it. Then I have to apply the water repellant spray. That's fine, its worth it to get these cleaned.
Anyone else try this?
Helios
Scampi 30 MK-IV
Old 12-08-2011
celenoglu's Avatar
celenoglu is on a distinguished road
Soap is may be the first cleaning agent made by humans. It is a combination of oil (or fats) with Sodium hydroxide. It is still used in Turkey and most countries. Its chemistry is different than detergents.
may be you an use mild detergents but it is best to use soap.
Old 12-08-2011
Minnewaska will become famous soon enough
I am very reluctant to take the covers off, as things like that never seem to go back together well for me. Sunbrella shouldn't shrink in the wash, but I'm still uneasy.
I wash mine in the spring with a very soft brush and spray Tuf Enuf, which use for everything, then hose them off and let dry thoroughly in the sun. Next year, I am going to apply 303 protectant afterward. 303 also makes a cleaner.
Jeanneau 54DS
Old 12-08-2011
treilley's Avatar
treilley is on a distinguished road
Use Woolite.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 12-08-2011
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
Sunbrella is an acrylic fabric. What you don't use any type of detergent. That can damage the fabric and remove the waterproofing. I follow the instructions in the link.
http://www.easyawn.com/pdf/CareAndCleaning.pdf
For Soap I use 303
303 Products, Inc.: Sunbrella Marine Fabrics Care Video
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Old 12-08-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Unless your cushions are made with an open cell foam (they shouldn't be) there is no reason to remove the covers for cleaning. Use a bucket with warm (not hot) water, Woolite and a bit of Oxyclean, and a soft brush and give the surfaces a good scrub and then flush with fresh water. Really tough spots can (usually) be removed with a shot of 409 and a splash of liquid bleach but should be thoroughly rinsed with fresh water. Then stand the cushions on edge and let them air-dry.
We have been using the foregoing method on our cushions for 10+ years with good results. If the cushion covers begin to show water absorption, you can treat them with some 303 water proofing.
FWIW...
Old 12-08-2011
treilley's Avatar
Originally Posted by svHyLyte View Post
Unless your cushions are made with an open cell foam (they shouldn't be) there is no reason to remove the covers for cleaning....
True for exterior cushions but interior cushions are usually made with open cell foam.
Tim R.
1997 Caliber 40LRC
and
Old 12-08-2011
jarcher's Avatar
It just seemed easier to toss the covers into the washing machine, although I don't know what soap is available that can pour into the washer. I'll try Woolite on one cover and see what happens. Thanks everyone!
Helios
Scampi 30 MK-IV
Old 12-08-2011
If it's a top loader, I would be worried that the agitator would put a beating on the stitching. Not sure about the front loader either.
Jeanneau 54DS
Cleaning / Washing Sails - Washing Machine ? Bleach ? Dennisail Gear & Maintenance 13 05-31-2010 06:08 AM
Cushion materials zz4gta Gear & Maintenance 6 05-07-2010 11:25 AM
Under Cushion Material Ronbye General Discussion (sailing related) 16 06-29-2007 10:28 AM
Cushion Covers simple72 Gear & Maintenance 3 11-09-2006 08:27 AM
Cabin Cushion Covers -- Annapolis billkidd Gear & Maintenance 2 09-01-2002 04:03 AM
