12-10-2011
Senior Moment Member
Originally Posted by santana30RI
No like a papertowel the cardboard
Just make a spacer yourself - Get a hunk of UHMWP and two hole saws of the appropriate diameters - one with an OD the same as the spindle shaft and one with an ID the same as the OD of the bearings (or a tetch smaller). Cut the large disc first then use the pilot hole from it to align the drill bit of the smaller one - Voila, a nice slippery, concentric UHMWP washer of the right size. Make as many as you need to stack for the proper thickness.
Remember, it doesn't have to be super precise - a bit of float between the upper and lower bearings is very usual in all the winches I've serviced over the years. If you can get it to 1/8" or so it should be good to go and probably better than the stock piece in a winch from before UHMWP was even available.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
