Bilge Pump Float Switch - Page 3 - SailNet Community
 1Likes
post #21 of 25 Old 12-14-2011
mitiempo's Avatar
I agree the connections should be covered with adhesive heatshrink. The wires on all float switches are long enough that they can and should be led as high as the space allows to keep them as dry as possible as well.
Brian
mitiempo is online now
post #22 of 25 Old 03-25-2012 Thread Starter
Re: Bilge Pump Float Switch
Now for the update.
After the expense and fun of installing the new switch, I'm pretty sure the old switch was just gummed up with bilge grime. It's soaking in soapy water now, if that works I will have a good spare.
The moral of this story is that it pays to remove a "broken" part before replacing it.
WanderingStar is offline
post #23 of 25 Old 04-04-2013
Our bilge pump float switch is sticking and not floating reliably. We store the boat in the water in winter and get water into the bilge through the mast (keel stepped). I am thinking we can just try to clean the switch and see if that solves the problem but can you tell me what is involved in replacing it? The skipper thinks that a new switch comes with the wires that have to be replaced along with the switch and is worried about making watertight connections. Thanks!
needsanap is offline
post #24 of 25 Old 04-04-2013
sailvayu's Avatar
All I can add is those who turn their pumps off or do not believe in float switches are job security for me :-)
I do several insurance claims every year on partially flooded boats where the battery was left dead, off or the pump was turned off. That is the real problem not sinking's but partial flooding causing damage to engines systems and interior wood work.
Capt. Wayne Canning, AMS
Project Boat Zen - Boat and Yacht Repair and Restoration
sailvayu is offline
post #25 of 25 Old 04-04-2013
mitiempo's Avatar
Originally Posted by needsanap View Post
...can you tell me what is involved in replacing it? The skipper thinks that a new switch comes with the wires that have to be replaced along with the switch and is worried about making watertight connections. Thanks!
Float switches come with a few feet of tinned wire attached. Properly crimped butt connectors w/heat shrink or separate heat shrink over the join will keep the water out.
Brian
Proper Float switch positioning for bilge pumps LittleWingCA Gear & Maintenance 5 09-16-2010 11:07 PM
bilge pump/float switch 3rd wire QuickMick Gear & Maintenance 3 08-27-2010 04:09 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Pump Float and Three-Way Switch Install max-on Gear & Maintenance 38 05-27-2008 03:45 PM
Quick question - bilge pump float switch pmoyer Gear & Maintenance 3 04-17-2007 04:43 PM
