Like Tree1Likes
  • 1 Post By allene222
Old 12-12-2011
cousineddy is on a distinguished road
Teak Sole Finish product?
Hi, I am putting in a new teak sole. I am replacing the veneer/plywood sole with real teak boads separated by a thin strip of something. It may be holly, but probably pine. I was thinking that I would use natural cetol, followed by gloss cetol. I know this will look really good but will this hold up? Is it possible to use polyurethane Gym seal instead? I know this holds up. Just dont know if it works on teak.
Oh, and what is the best glue to use for the teak board? They will be bonded to the marine plywood floor board.
Thanks!
Old 12-12-2011
safira's Avatar
safira is on a distinguished road
just a suggestion but the putty tape works great
Old 12-12-2011
mitiempo's Avatar
If you are permanently attaching the teak I would use epoxy - both under and between the planks. Thickened a bit and put on with a serrated trowel. Acetone wipe first before the epoxy works well.
For the lighter wood pine is pretty soft - maple or ash would be better choices.
The Gym seal should work - again after removing dust acetone wipe to degrease the teak.
Brian
Old 12-12-2011
kb3pwc's Avatar
kb3pwc is on a distinguished road
IMO Cetol is a wonderful product but not hard enough to use under foot. I use it in about 6-7 coats (gloss clear) on our outside teak and it is a thing of beauty but wears away and is only in need of a scrubby pad before next coat. Heavy traffic would give it too much wear.
Leslie
s/v Tango, Cabo Rico 34
On the Hard
Lankford Bay Marina
Chester River, MD
Old 12-12-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
I agree that epoxy is what to use to bond the wood.
As to finish, either spar varnish or polyurethane floor finish would work. The poly would be more durable and should be fine inside.
Old 12-12-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I recently refinished two soles, one was done with cetol, it looks great but in my opinion is too soft for that app and is very slick under wet feet. The other one was done with warmed tung oil, it also came out beautiful, brought out all the colors of the wood and is not slick ( personal perference )
T88 is a great/easy to use 1:1 two part adhesive that resists chemicals and rot
Pine maybe to soft and tends to invite mold and rot
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 12-12-2011
allene222 is on a distinguished road
I redid my cabin sole with some teak and holly ply in 2001 and had to decide how to finish it. My goal was to have a surface that I would not slip on when it was wet, would hold up to the elements, and be low maintenance. I think that is what teak and holly are all about. Holly is white and doesn't turn black when it gets wet. Pine and most other white woods turn black when they get wet. That is why they use holly.
I have no varnish on mine and it does not slip when it gets wet. I use some teak oil every few years. It looks fine but not like it would if it was varnished but then it would not meet my goals. I personally don't understand why people take a wood that needs virtually no maintenance, has all these great properties and varnish it. Especially since having varnish stick to it is not one of its great properties.
Old 12-12-2011
mitiempo's Avatar
Going back a few decades it was teak, usually without the holly, and just scrubbed occasionally.
I like solid teak (or cherry) varnished with strips of non skid created with ground walnut shells under the varnish like below. Not mu boat by the way - the pic is from Dashew Offshore.
Brian
Tags
cetol , finish , holly , sole , teak
Teak finish H and E Gear & Maintenance 15 10-02-2011 11:41 PM
Re-finish sole elcap373 Newport 2 04-13-2009 10:23 PM
Good Product: Synthetic Wood Finish labatt Gear & Maintenance 2 11-05-2007 05:34 PM
Finish for the cabin sole shantijwk Gear & Maintenance 11 04-22-2007 10:22 PM
Cabin sole finish captchase Gear & Maintenance 15 03-31-2002 09:32 PM
