Old 12-12-2011
SanDiegoChip's Avatar
SanDiegoChip is on a distinguished road
Fusing solar panel junction
Hi,
We just wired up our buss that goes to our solar controller. We added one more panel than the picture shows. Any way there are two wires from each panel. One neg and one positive and they go to each side of the buss.
My question is do we need a fuse on each solar panel positive cable? They are #10 and would be a 15 amp fuse.
We do not want to go through the time and expense of fusing each panel. Of course if needed we would do this to avoid a fire but is this really needed?
[IMG]Photobucket[/IMG]
Thanks,
Chip
Old 12-12-2011
Sorry this post was supposed to go to "Electrical".
Chip
Old 12-12-2011
mitiempo's Avatar
I would fuse them - individually.
Brian
Old 12-12-2011
AdamLein's Avatar
AdamLein will become famous soon enough
I seem to remember reading advice of the form, "fuse any wire that goes to the battery + post, as close to the post as possible." So assuming the + side of your bus goes directly to battery +, that's what I would fuse.
Probably I read it in Don Casey's "Sailboat Electrics Simplified."
p.s. that said if you have, say, a 9A fuse on the bus's + wire and each panel puts out 3A, then an overload in any of the panel wires won't necessary blow the fuse. Of course, it's not clear to me, short of, well, a short, how a panel wire might overload.
s/v Essorant
1972 Catalina 27
Old 12-12-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
A trick question. Without knowing the size of the panels and the wire...
...we have to guess.
If they were small, under the capacity of the panel or connecting wiring, I think not. But if those are large panels, and I assume they are, individual fuses may be needed. And there will certainly be a fuse between the controller and the battery.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
solar panel QuickMick Gear & Maintenance 11 12-11-2009 02:56 PM
solar panel alan_21_us Gear & Maintenance 12 07-31-2008 10:18 PM
B32 & Solar Panel Dcneuro Bristol 2 07-26-2007 10:56 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 11:02 AM
Solar panel ldbarker Gear & Maintenance 3 10-27-2002 01:31 PM
