Iron Keel Renovation - WS Epoxy vs Barrier Coat for first sealing layer - Page 2 - SailNet Community
post #11 of 11 Old 12-13-2011
Senior Moment Member
SloopJonB's Avatar
Originally Posted by Rhodes143 View Post
Thanks sailing fool, so you are recommending to wet on (no fillers) 3-5 layers of West then add the filler compound to fill in remaining voids. Then do one final wet layer?
By now I think you understand why I made the following comment in my reply to you.
I chose three coats of epoxy resin followed by two coats of InterProtect. This was mainly due to some rather widespread disagreement as to what was best at that time. I think now that I would use just Interprotect.
Seems like nothing has changed!
SloopJonB is offline
Epoxy Barrier coat stevemorrell Gear & Maintenance 7 01-15-2016 02:32 PM
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 10:08 PM
Cast Iron Keel Renovation - WS Epoxy vs. Barrier Coat first sealing layer Rhodes143 General Discussion (sailing related) 10 12-14-2011 12:14 AM
tar epoxy barrier coat on fiberglass erpwyeth Gear & Maintenance 2 06-13-2010 08:30 PM
EPOXY BARRIER COAT DILEMMA, help ..... Freesail99 Gear & Maintenance 5 06-07-2010 08:14 AM
