Old 12-12-2011
Cruiser2B's Avatar
Cruiser2B is on a distinguished road
StainlessStanding Rigging 1x19 302/304 vs 316
I am about to replace my standing rigging i will use sta-lok fittings. is there a need to use 316 for the wire? I understand it is less corrosion resistant than 302/304 but it is also weaker. My Alberg rigging is 41yrs old, hence the replacement, I am assuming they used 304 back then but not too sure so i am asking here, what have you used and what was your reasoning for choosing it. i dont mind spending the money if it is necessary Thank you
Old 12-12-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
316 is MORE corrosion resistant than 304, not less. That is its benefit. It is supposedly a bit weaker than 304 but I've never seen that on any engineering tables or anything, just commentary.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 12-12-2011
mitiempo's Avatar
I would use 316, which as posted above is more corrosion resistant than 304.
My local rigger only stocks 316 as the demand for 304 is almost non existent.
Brian
Old 12-13-2011
Cruiser2B's Avatar
Thank you, i meant to say that 316 was more corrossion resistant..my mistake. I appreciate the input. I dont mind spending the extra money on 316 but if it is not completely needed why waste the money. thanks again
Junk/Sampan rigging vs. Cat rigging ClaireFAISE General Discussion (sailing related) 10 09-21-2010 08:59 PM
ID this rigging MtHopeBay Gear & Maintenance 5 10-26-2009 09:23 PM
jib rigging on a Cal 20 CAL20ALCHEMY Cal 1 05-27-2007 11:50 PM
Does your rigging have this? superdave Gear & Maintenance 17 05-26-2007 11:23 AM
J/40 rigging i670684 Gear & Maintenance 2 05-08-2006 04:57 PM
