Purpose Of This Compass - Page 2 - SailNet Community
post #11 of 22 Old 12-14-2011 Thread Starter
casey1999's Avatar
Originally Posted by adamsj23 View Post
My bulkhead compass has the clinometer, but the lubber lines don't move, could they be stuck or am am reading wrong? Obviously wouldn't want them to turn.
As I remember the lubber lines stay vertical but do no rotate. Then you just read the number on the clinometer. Sounds like yours may be stuck.
casey1999 is offline
post #12 of 22 Old 12-14-2011
tommays's Avatar
On a boat like the J24 with a tiller you have one on both sides of the cabintop so you have a good line of vision on each tack
But i always liked my mast mounted sailcomp the best and the fluxgate compass is great IMHP
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 22 Old 12-14-2011 Thread Starter
casey1999's Avatar
Ok, but I see somthing else. What do you call they way you have rigged the tack of you main sail? Looks like the tack connection is actually above one slide. I might need to do somthing like this to get my main sail to fit correctly.
post #14 of 22 Old 12-14-2011
tommays's Avatar
it is a cunningham pretty standard at least on race boats
There are no winches for haylard so that one and the one on the jib allow a lot of sail shape changes fast and easy
Tommays
Northport NY
tommays is offline
post #15 of 22 Old 12-14-2011 Thread Starter
casey1999's Avatar
It looks like the lower 6 inches or so of the main sail at the tack will always be loose as there is nothing holding it down. Is that what someone refered to as a loose tack?
post #16 of 22 Old 12-14-2011
tommays's Avatar
You dont see it well in the picture BUT there is a pin in the boom holding the sail
Tommays
Northport NY
tommays is offline
post #17 of 22 Old 12-14-2011
Arpegecap's Avatar
The photo shows a Cunningham. It is used to adjust the luff tension on the main which helps controls the draft.
Arpegecap is offline
post #18 of 22 Old 12-14-2011 Thread Starter
casey1999's Avatar
I believe you, but I blew up the pic and still don't see a connection of the tack of the sail to the boom- I do see the cunningham connection.
post #19 of 22 Old 12-14-2011
Senior Moment Member
SloopJonB's Avatar
Originally Posted by casey1999 View Post
I believe you, but I blew up the pic and still don't see a connection of the tack of the sail to the boom- I do see the cunningham connection. Regards
I agree, it looks like the Cunningham tension has eased the pressure on the tack enough that it slid off the tack horns.
Does that qualify as a "loose footed main"?
SloopJonB is offline
post #20 of 22 Old 12-19-2011 Thread Starter
casey1999's Avatar
I don't know but I was messing with my main sail the other day and basically they way you have it rigged is the only way I can get proper luff tension. For some reason I cannot get enough luff tension with the main halyard but if I use the main haylard in conjunction with the cunningham, I get good tensioin. I wonder if my slides jam going up then need to be pulled down to free them up?
Purpose of Winches Rustyf General Discussion (sailing related) 7 11-15-2011 01:35 PM
What is this antenna's purpose? BEENONLANDTOOLONG Electronics 4 07-04-2011 03:07 PM
Racing is cruising with a purpose... really? mollyspinsheet General Discussion (sailing related) 49 05-27-2011 05:19 PM
Best Boat for my purpose? Advocate777 General Discussion (sailing related) 7 09-30-2010 10:32 AM
Looking for a boat for the following purpose: thalassolikos Boat Review and Purchase Forum 1 04-04-2004 04:40 PM
