-   -   Purpose Of This Compass (http://www.sailnet.com/forums/gear-maintenance/81721-purpose-compass.html)
casey1999 12-13-2011 06:21 PM
1 Attachment(s)
Boat has a Contest compass (bulkhead type). The compass is confusing because it has these colored bands with numbers from 0 to 5 and then repeats. What is the purpose of these numbers and color bands? If you look into the compass on the far side of the rotating horozontal dial you will see the normall 0-360 reading- but this is very difficult to read. Why is the compass set up like this?
jackdale 12-13-2011 07:07 PM
Loki9 12-14-2011 09:30 AM
I haven't used one like that, but I think the purpose is to let you steer the same number as you tack back and forth toward a windward goal. For example, on the first tack you find yourself steering red 2, then on the next tack you'll want to steer a black 2.
casey1999 12-14-2011 12:09 PM
Thanks, makes sense. I tried to find a manual on line but no luck yet. Will try it next time I tack.
celenoglu 12-14-2011 12:34 PM
the brochure says it is a inclonometer. I do not know how it works but worth to check.
casey1999 12-14-2011 12:43 PM
I believe they are refering to the level type device at the base that will tell you angle of heel.
jackdale 12-14-2011 01:04 PM
Many bulkhead compasses have an integrated inclinometer. You can read the heel angle from where the lubber line intersects the scale.
tommays 12-14-2011 01:07 PM
Even on a small boat like a J24 You need two of that type unit to very usefull
casey1999 12-14-2011 01:12 PM
How would you use two?
adamsj23 12-14-2011 01:23 PM
My bulkhead compass has the clinometer, but the lubber lines don't move, could they be stuck or am am reading wrong? Obviously wouldn't want them to turn.
