Old 12-13-2011
santana30RI is on a distinguished road
md6a thermostat
I have a Md6a Volvo motor i just did work on and found there was no thermostat. I go the boat in July and it has been in the water running with no problem how bad is this?
Thanks
Old 12-14-2011
Capt Len is on a distinguished road
Assuming it is fresh water cooled ,no biggie. the engine takes a long time to come to temp if ever. Engine runs better and certainly more efficiently with the proper thermostat to control this. Your engine temp gauge becomes useful and looking at it can tell a lot about conditions below.
Old 12-14-2011
It it raw water cooled
Old 12-14-2011
shogan50 is on a distinguished road
it will be more efficient with the thermostat. Volvo gets $75 for the one with their name on it. You can find equivalent at NAPA for a fraction. If in salt water, use 140 degree. If fresh water, use 160 or 180.
Islander 30 MKII "Sojourn"
Old 12-14-2011
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Our raw water cooled Bukh never got up to anything like a good operating temperature, nor did Volvo MD6b in boat before that. Seems to me that unless they have a plastic bag sucked up into the system raw water donks just don't get hot.
Old 12-15-2011
ebs001's Avatar
ebs001 is on a distinguished road
Running a diesel below proper operating temperature produces condensation in the fuel. A diesel should always be run right at the rated operating temperature. The thermostat is there to maintain that temperature.
Cruise speed with Volvo MD6A diesel talbot Gear & Maintenance 7 10-26-2009 10:07 PM
MD6A cooling water circuit.. groundhog Gear & Maintenance 0 09-11-2008 05:37 PM
MD6A Replacement Oil Filter scurvy Gear & Maintenance 5 09-20-2007 10:57 AM
MD6A Woes scurvy Gear & Maintenance 15 07-29-2007 05:55 PM
MD6A compression test adaptor.. groundhog Gear & Maintenance 2 06-14-2007 01:50 PM
