whisker pole ends - Page 2 - SailNet Community
post #11 of 13 Old 12-30-2011
Originally Posted by speciald View Post
Measure your J length not the foot of your head sail. For racing, a pole can be J + 10% at its longest.
Yes, that would be for a standard (no penalty) SPL (Spinnaker pole length) Typically whisker poles would be longer..
Faster is offline
post #12 of 13 Old 01-02-2012
Forespar confirmed was an old model telescoping wisker pole and not a reaching strut despite the open hook end. The sheet went on the roller, sail was not directly engaged. they sill suggest not attaching to the clew due to possible impact on the sail shape (twisting). i suspect reason they changed to 2 snap ends was due to sheet disengaging too easily. i'm planning to use a foreguy and topping lift and see how it goes. if disengagement problem can always modify or replace the hook end.
my J length is 14+ so the 7-17 appears to fit my boat.
dave22q is offline
post #13 of 13 Old 01-08-2012
e-bay
go to e-bay pick up new ends and replace
gaha is offline
How to buy a whisker pole.... MedSailor Gear & Maintenance 11 02-28-2010 07:28 PM
Whisker Pole? Ajax_MD Learning to Sail 6 01-22-2010 08:01 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 03:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 03:10 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 09:00 PM
