Old 12-15-2011
Brillig is on a distinguished road
replacing sails
My 31 ft Pacific Seacraft Mariah (cutter rig) is in need of some new sails. The yard is recommending 110% Roller Furling Dacron Genoa, 110% Roller Furling Dacron Staysail and a Dacron Main with two reef points and four battens. I believe in keeping things as simple as possible, so my initial reaction is to not go with the Roller Furling gear and to shop for used sails. I will be singlehanding.
Your thoughts and advice are greatly appreciated.
Old 12-15-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Currently no roller furlers? If not, adding two will run a bit of money, so I hear your concern. Finding used headsails is easier than finding a main as you have more flexibility, especially for hanked sails. There is something to be said for roller furlers when single handing however.
Old 12-15-2011
capttb is on a distinguished road
I think modern reliable furlers make sailhandling and sailing much easier, especially for solo sailing. There are times when you must reduce sail and leaving the helm is dicey, being able to furl while within reach of the tiller can be "priceless".
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 12-15-2011
celenoglu's Avatar
celenoglu is on a distinguished road
Used sails for forward sails is not a god idea.
Old 12-15-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
"...and on the 8th day God created used genoas!"
Sorry, couldn't resist.
Old 12-15-2011
peterchech is on a distinguished road
On a smaller home built boat I rigged up a line that went to the head of the jib, and ran parallel to the forestay. I ran it through a block at the bow, and back to the cockpit. This allowed me to drop the jib from the cockpit. I am considering getting rid of the furler on my current boat and installing the same system. You still have to hank/unhank at the end of the day, but in a pinch you can drop sail from the cockpit. Nets under the lifelines forward would help prevent this dropped jib from falling overboard.
Old 12-15-2011
Squidd's Avatar
Tacky yet Unrefined
Squidd is on a distinguished road
Care to expand ?...been thinking of adding to my sail set but don't want to pay new prices if I can reasonably avoid it...?
"Might as well cast off...If anything bad is gonna happen...It's gonna happen out there..."
"Captin Ron"
Old 12-15-2011
meteuz is on a distinguished road
Might be best to have roller furling on the forestay but not on the inner stay so that you can hank on a storm jib.
Old 12-15-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Squidd, only reason to get used sails is if you have a competitively raced OD type boat and can get newer sails for 1/2 the cost of new. Any other sail is going to be a re-cut, screw up from the sailmaker, or past it's useful life as a sail.
Merit 25 # 764 "Audrey"
Old 12-15-2011
arknoah's Avatar
s/v Ilya
arknoah is on a distinguished road
Makes sense.
Having the option is really valuable.
Ilya's Adventures:
____________________________
And straight on 'til morning
Racing Sails Vs. Cruising Sails??? NewportNewbie General Discussion (sailing related) 2 10-27-2011 02:25 PM
Replacing windows Dick Pluta Gear & Maintenance 30 02-03-2010 05:58 PM
North Sails vs North Sails Direct DrB Gear & Maintenance 0 06-25-2009 09:00 PM
Teralani Sailing Adventures - Snorkel Sails, Sunset Sails and Whale Watched from Kaanapali Beach, Maui (About.com) NewsReader News Feeds 0 10-06-2006 11:15 AM
Replacing Seacocks marleypc Gear & Maintenance 3 12-30-2002 02:56 PM
