Old 12-15-2011
bdietrich is on a distinguished road
Vinyl-coated cockpit cushions
I'm trying to find a cheap source of vinyl-coated (sealed) closed-cell foam cushions for the cockpit. Similar to those sold by bottomsiders or other marine stores, but they want $1200 or so for a set of 3 or 4 cushions.
I need a simple rectangular cushion, about 48 x 16 x 3.
Can find cheap "stadium cushions" on Amazon for $10; right construction but much too small. Found these "pool cushions" that are closer: Foam Pool & Spa Seat Cushion 2-Pack Oval SS59222SET
Anyone know of a good source ? Thanks.
Bill Dietrich
sailing vessel "Magnolia": 1973 Gulfstar 44 ketch motor-sailer
Old 12-15-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
The difficult-custom-cheap route would be to build your own. You could get foam for about $65-70 (Polyethylene Foam, Roll, Tubes, Polyethylene Closed Cell Foam Sheets), and fabric for about $70 (Solids at OutdoorFabrics.com), and instructions for $5 (sailrite.com).
Old 12-15-2011
RobGallagher is on a distinguished road
The seats sold to put on top of coolers may even have snaps!
They are pretty cheap if you shop around.
Old 12-15-2011
remetau's Avatar
remetau is on a distinguished road
We bought ours from C-Cushions. They custom make them based on your boat, but I'm sure they would be willing to do whatever you needed.
Don & Diana
sv Re Metau an HC33t
Old 12-17-2011
Barquito: I don't want fabric-over-foam; I want sealed vinyl over foam.
RobGallagher: I'm pretty sure cooler-tops are the wrong size (too deep, not long enough, probably not thick enough), but I'll check.
Remetau: C-Cushions looks pretty expensive, in the $1000+ range. I forget the exact number they gave me for my boat.
Bill Dietrich
Old 12-17-2011
RobGallagher: okay, I was wrong, Igloo has a cushion that's a possibility: 39 x 16.5 x 2.75 for $72. Thanks.
Bill Dietrich
Old 12-17-2011
ereiss is on a distinguished road
I went the sail rite route, not an experienced sewer, watched the video and simply followed the instructions. Pretty happy with the outcome.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
Old 12-22-2011
Ordered one of these: Walmart.com: Igloo Seat Cushion Marine Cooler - White, 128-Quart: Camping Not quite the technology I wanted, but I'll see how well it works.
Bill Dietrich
Old 12-22-2011
Irrationally Exuberant
arf145 is on a distinguished road
I hope you come up with something. I researched along the same lines last year and couldn't find a real substitute. C Cushions and Bottomsiders both cost about the same--maybe C is 100 bucks cheaper.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 12-23-2011
baboon is on a distinguished road
If the igloo product does not work out the bottomsiders might be worth another consideration, depending on how long you plan to keep the boat. Mine came with the boat so I did not have to deal with the cost, but they are about 15 years old and have held up very well. They are dark blue and a bit faded, but otherwise still work great.
Cockpit cushions SpeedAgent Gear & Maintenance 33 11-16-2010 12:26 PM
Replace vinyl on bottom of cushions or not? jskrypek Gear & Maintenance 10 06-20-2009 12:29 PM
Cockpit cushions arf145 Gear & Maintenance 14 04-12-2009 01:06 AM
Lifelines: Bare Wire vs. Vinyl Coated Debate Sabreman Gear & Maintenance 19 12-25-2008 11:50 AM
Cockpit Cushions kdmjme Gear & Maintenance 7 11-05-2007 12:13 AM
