12-16-2011
Senior Moment Member
Originally Posted by jameswilson29
Yes, I was rapping on it with the handle of the scraper I was using and it sounded different from the surrounding area, although it is difficult to tell because aft of it is a cabin bulkhead, below is the reinforced bilge sump area, forward is the main bulkhead...
I would have to cut into the liner to access this area for an inspection. I am not sure I would recognize the difference between damaged laminate and undamaged laminate.
It's usually pretty obvious, likely you'll recognize it when you see it.
Could I pop the area out using a jack between the hull and the liner or tapered wood pieces hammered into place temporarily?
Yes - I wouldn't use a jack though - you might be able to pop it out by hand with a piece of broom handle or similar. Go easy at first and increase the pressure slowly, don't START by smacking it with a big hammer.
Would there be any harm in adding laminate and stringers to reinforce this area?
Nothing but good could come from this.
(I did not intend for this to be a "project boat", although it seems to be becoming one; the boat is inexpensive enough I am hesitant to pay for professional fiberglass repairs.)
ALL boats are "project" boats. It's just a matter of how much of a project they are.
P.S. If you do decide to cut into the liner, plan it carefully so you can make it look good later - like a planned and designed access port. Nothing screams "uncaring owner" quite like crude holes hacked in a moulded liner.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
