12-16-2011
s/v Black Prince
Plastic holding tanks- Are they legit?
My orginal gravity operated holding tank which was built into the hull with fiberglass matting was recently replaced because after 25 years it appeared to be deteriorating. Instead of doing a patch job, the yard recommended a plastic tank. So after about $1,800 to build a shelf, buy the plastic tank in the shape to maximize size, custom configuration of tank outlets, installation, etc., I lost about 10 gal of capacity...and of course now have a tank that is leaking from the bottom hose fitting to the tank. After finding the leak, I puzzled about what would cause the leak in what appeared to be a secure and caulked connection. Then I noticed when flushing the toilet that the sides of the tank were moving with the pressure created by pumping and sinking inward when the tank was emptied. I know the first reaction will be to check to make sure vent is not clogged. But if a clogged vent...which happens....will render your plastic holding tank vulnerable to malfunction, why take the chance of installing such a vulnerable system instead of installing a more rigid tank?
Has anyone had similar experience with the plastic holding tanks? And is there any way too insure that pressure differences won't occur? For instance I would think that when a pumping station hose sucked the plastic tank empty it would also tend to cause the sides of the tank to draw in. Any repeated movement of the tank wall would seem to eventually cause even the best hose connections to leak.
s/v Black Prince
