Old 12-20-2011
priceless9192 is on a distinguished road
centerboard repair using bondo
I recently bought a 17 foot boat with a iron swing centerboard. The boat was sitting for many years and the centerboard was rusted up inside the boat. Upon removal I noticed large flakes of rust coming off of it, so I flaked it all off and sanded it roughly to get it back to raw iron. I am on a super tight budget and I plan to use bondo to make up the missing width. I just need advice whether this is going to work underwater. Could someone give me some guidance?
Old 12-20-2011
Maine Sail's Avatar
Bondo tends to absorb water. You'd be better off with a vinylester putty or make your own mix with cabosil, milled fibers and epoxy. You could make the same cabosil/milled fibers putty with polyester resin too..
______
-Maine Sail / CS-36T
Old 12-20-2011
celenoglu's Avatar
celenoglu is on a distinguished road
Epoy is the best product for underwater. Bondo also has a epoxy putty. I would have used epoxy + glass dust to prepeare a putty. First apply clear epoxy then use the putty.
Old 12-20-2011
FDR14127 is on a distinguished road
Bondo makes a marine product which I have used on my keel in the past. I haven't noticed anything since I applied it maybe five years ago. When I go to the yard tomorrow I will give it a look and let you know if it has changed.
s/v Nemesis
Niagara on the Lake Sailing Cub
Old 12-20-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
The missing width isn't a structural part, is it? If not, you could just paint it, and be a fraction of knot slower.
Old 12-20-2011
Ulladh is on a distinguished road
Clean off all the loose rust and paint with a rust converter.
Mar-Hyde(R) One-Step(R) Rust Converter Primer Sealer
3M also makes marine bono, and resins for other repackaged/renamed coatings.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Old 12-20-2011
i think the rust converter is out of the question now that i have grinded the rust off with a few hours and a wire wheel on a drill. i will look into the bondo marine product. and no it is not structural but i would like to have it back to original size to sail fast
Old 12-20-2011
sfchallenger is on a distinguished road
Sounds like what you are looking for is a fairing compound. I'd use West Systems - they make two part epoxys with various additives to add thickness/give the product a heavier consistancy (the resin by itself is quite runny). You can apply it/work it much as you would bondo, it behaves similarly in terms of how it 'gells' when it is going off.
Sailing a '74 Challenger 40' Ketch rig out of San Francisco
Bondo Glass??? 4cylindersoffury Gear & Maintenance 24 09-05-2010 03:49 PM
centerboard jebsailor Gear & Maintenance 1 09-02-2009 08:45 AM
Centerboard niktash Mariner 1 05-25-2009 01:24 PM
how is bondo for boats? Captain_Rick General Discussion (sailing related) 8 03-26-2007 05:51 PM
O''Day 25 centerboard Jocelyn(Nipan2) Gear & Maintenance 1 01-22-2005 09:17 PM
