12-22-2011
Senior Slacker
Pressure wash, and a plastic putty knife for the tougher stuff, right when you pull it out of the water will take almost all the fouling. For harder or more tenacious critters (barnacles, tube worms, etc.), you may have to use a Scotch-pad-like scrubber or a metal scraper.
Any fouling (algae, barnacles, whatever) will increase drag on a boat hull. You want the bottom to be as smooth as possible (if anyone mentions golfball dimpling, etc., just laugh and walk away). In addition, that thin layer of slime that first develops on the hull surface (what marine biologists call "biofilm") will actually attract and provide a suitable environment for larger algae and other fouling organisms. The best way to prevent a build-up of fouling is to have the bottom regularly cleaned by a diver using a soft cloth to wipe off the biofilm and any small fouling organisms (before they can grow into big fouling organisms).
