12-25-2011
Tartan 27' owner
Originally Posted by 75Tartan30
Yes its a 1989 Universal Diesel with fresh water cooling. Its actually giving me a bit of a fit right now as I am having trouble getting it to turn over. The PO admitted there was a wiring issue that let it fire right up sometimes but other times it wouldn't turn over. I have chased the wiring back to the starter and all looks ok so I was thinking it may be an issue with the control panel. When I hold the glow plug button everything is fine and the buzzer is going off but when I press the start button the buzzer and light on the control panel dim way down like there is a big load on the circuitry. But at least the engine isnt buried in the stern of the boat. S&S new what they were doing when they designed this version of the Tartan. All that weight right in the center of the boat way down low with excellent access plus its mounted right on top of the lead keel which dissipates any vibration.
Sometimes it can be the ignition switch itself that is the problem. I wonder about any electrical brushes in the starter motor itself too. Hopefully someone with more expertise in this area will chime in.
If the glow plugs are working it should start up pretty easily I'd think.
Probably time to break out your multi-meter.
If you don't already own it, Nigel Caulder's "Boatowner's Mechanical & Electrical Manual" is a great resource that covers engines, wiring and many other items in great detail (wiring diagrams, photos etc.). Well worth the ~$40 considering most decent engine mechanics charge ~$80/hour.
Good luck chasing down those starting demons!
