Hauling boat home for painting - Page 2 - SailNet Community
 1Likes
post #11 of 20 Old 01-03-2012
I recently had my 27' hauled out and placed in the back yard for $300, one way, plus the cost of 5 jackstands at $125 each. It took the guy about two hours with a hydraulic trailer from meeting at the ramp to placing on stands in my yard and him leaving the house.
I plan on bottom painting and working through the electrical system over the next several months on my own time with all tools nearby.
Although, initially expensive it turns out to be much cheaper over several months than keeping at a marina and paying yard fees (for the bottom paint). It is a chance to do a thourough survey of the boat without worrying about accruing extra storage costs for unforseen issues that always come up!
follysurf is offline
post #12 of 20 Old 01-25-2012 Thread Starter
SanSimon's Avatar
who did the haul?
Hi and thanks for the info. Who was your hauling co. And how did you find them?
SanSimon is offline
post #13 of 20 Old 02-02-2012
It was an individual with a trailer. I got his name from talking with people at the yacht club. He is basically the only person in the area with ability to transport keel boats. Although I have seen a company called Dolphin Enterprises on craigs list that I beleive to be a national company.
I am in South Carolina.
post #14 of 20 Old 03-10-2012 Thread Starter
SanSimon's Avatar
building a trailer
You wrote in your post that you "built" a trailer - how did you do that? And do you have any pictures? Thanks in advance! DK
SanSimon is offline
post #15 of 20 Old 03-10-2012
Superior Sailor
Squidd's Avatar
Re: Hauling boat home for painting
I don't know if your asking me or Gary, but here's what I did on mine...
First trailer is a flatbed equipment trailer I built a temporary wood cradle to haul the boat home when I first bought it... Keel is blocked to bed and cradle just "balances" boat...
Second one is more permenant "dry slip" trailer to haul out in spring and haul home in fall.. not a "day to day" road trailer... but with a keel stepped mast it's not practicle to move around too much...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #16 of 20 Old 03-11-2012
Re: building a trailer
When I built my trailer I was about 28 at the time 30 years ago! I bought some hot roll channel steel and a pair of axles and springs from a mobile home company. I also had a piece of 3" box tubing and a piece of 4" box tubing that I used for the tongue. I used a couple of short pieces of pipe welded into the frame with scaffold jacks on them to hold the boat up.
The frame was really simple, a pair of long channels that we notched and bent to an A frame at the front. Four channels across the bottom of the side channels with the axles between. The side channels sat on top of the spring hangers which were welded on. The square tube at the front just went under the A frame and welded into the front cross channel. A second square tube slid inside with a pin to change the length of the trailer, a waste of time in reality. A couple of planks got bolted to the cross channels for the keel to sit on. Some pieces of pipe sitting on the four cross beams got four screw jacks on each side with a large piece of plywood to spread the load against the hull.
A friend helped me. On Saturday we cut and welded the frame together. On Sunday I painted it, and the following Saturday added the wiring for lights and license plates. My brother-in-law still owns the trailer, he uses it fro hauling large spools of wire.
Gary H. Lucas
GaryHLucas is offline
post #17 of 20 Old 03-11-2012
benjmin's Avatar
Peter Hamm?
benjmin is offline
post #18 of 20 Old 03-13-2012
Originally Posted by benjmin View Post
Peter Hamm?
Thats the guy.
post #19 of 20 Old 03-13-2012
benjmin's Avatar
Peter Hamm hauls my sailboat. He has prices that can't be beat IMHO.
Peter Hamm
His voicemail is always full
(843) 696-0278
benjmin is offline
post #20 of 20 Old 03-13-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
FWIW - Independent Boat Haulers in Eliot, ME just quoted me $720 to move a Catalina 25 50 miles.
Not sure if I getting screwed or not; the other company never called back; and the clock, she is ticking!
I know people who have used IBH and they do good work.
My new (to me) bottom gets wet May 11!
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
Boat Painting willysail Gear & Maintenance 5 07-08-2011 10:11 PM
Painting my boat BigBird271 Gear & Maintenance 8 08-13-2009 06:18 PM
Suggestions for interstate boat hauling in NE CheoyLee36 General Discussion (sailing related) 8 09-10-2008 09:58 AM
Need a better mast support while overland hauling the boat NewsReader Mass Bay Sailors 0 10-10-2006 08:15 AM
boat hauling cgha33 General Discussion (sailing related) 1 08-20-2003 11:21 AM
