bottom paint barrier coat - SailNet Community
Blogs
Old 02-25-2001
rbh1515 is on a distinguished road
I want to put VC17 bottom paint on my sailboat. What should I use as a barrier coat. Any recommendations? What have others used?
Old 02-25-2001
KenWalker is on a distinguished road
Last year I had the yard take my bottom down to the gel coat and put on 3 coats of Interlux Micron on my 11 year old Sabre. Before having them do the work I talked with tech support at Interlux. They told me NOT to use a barrier coat on a boat that has been in the water for any length of time. They said the hull will absorb moisture and the barrier coat will trap the already aborbed moisture causing the newly applied paint to fail.
Old 02-25-2001
Thanks for the info. My boat is older, and i''m having the old paint removed. How did you remove you old paint. Is the micron like vc17? Rob
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 10:18 AM
Bottom paint for dinghy? prussell Cruising & Liveaboard Forum 1 07-24-2003 02:10 PM
Bottom Job question(s) rookie00 Gear & Maintenance 19 03-19-2003 04:01 AM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 05:53 PM
To Paint bottom or not? rightlife Gear & Maintenance 0 01-02-2001 09:40 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
