Like Tree2Likes
Old 12-31-2011
PCP PCP is offline
PCP is on a distinguished road
Normal Humidity on a Hull?
Wishing everybody a great night and a great new year, I need the answer to a question:
What is the normal humidity tax on a 5 year old hull of a boat that is out of the water for about 6 months , I mean a fiberglass cored hull?
What is a good percentage, a normal one and a bad one?
Old 01-01-2012
PCP PCP is offline
come on guys, I need the correct answer to that question!
Old 01-01-2012
celenoglu's Avatar
celenoglu is on a distinguished road
Reading on wood scale of 10 - 12 % is normal. That means 1 - 1.2 % of humidity in fiberglass. Up to 17 % is acceptable. Below 10 % is dry. 7% on wood scale (0.7%in fiber) is the accepted for application of protective coats such as epoxy. Appliying epoxy to more humid hulls can cause problems later.
PCP likes this.
Old 01-01-2012
tdw's Avatar
tdw tdw is online now
Super Fuzzy Moderator
I am of no use to you on this question Paulo old friend, but I do hope all is good for you for 2012.
Salute
Andrew
Old 01-01-2012
PCP PCP is offline
Thanks,
I am only interested in fiberglass and particularly cored hulls.
For what I understand from what you say, a very dry fiberglass hull will have 0.7% of humidity in the hull, the normal would be between 1.0% and 1.2% and more than 1.7% is not acceptable?
Can you provide some links that permits me to learn more about the matter?
If not can you send me some paper about it by email. I am not doubting you just this is very important to me right now.
Thanks again and a good new year to you.
Old 01-01-2012
PCP PCP is offline
Salute
Andrew
A great year to you too.
Maybe you can. I guess you have your Malo surveyed before you bought it. Can you see what were the values of humidity the surveyor found on the hull? You can send the information by private message or email.
Old 01-01-2012
cruisingdream is on a distinguished road
Understanding the Moisture Meter / Electrophysics CT-33 Photo Gallery by Compass Marine at pbase.com
Old 01-01-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
The little "moisture meters" marketed for such purposes are fine for giving one an idea of the relative differences in moisture in various locations of a particular hull, but are essentially worthless for determining the absolute water content. In other words, if most of the hull (below the waterline) gives you a fairly tight range of readings and one area (or a few areas) has higher readings that is something about which you should be concerned. However, the "percent moisture" indicted has little or no relationship to the actual amount of moisture in the fiberglass. The little "moisture meters" on the market just can't make that analysis with any reliability across different fiberglass resins, bottom/barrier treatments, etc. Anyone who tells you otherwise registers a pretty high "percent BS" on my patented "BS meter".
StormBay likes this.
Old 01-02-2012
PCP PCP is offline
Thanks,
The humidity scale that they show in the article confirms what Celenoglu had said about the subject. The surveyor used a bigger and more complex instrument and he says he is going to use an even more powerful one (from another surveyor).
Thanks
Old 01-02-2012
celenoglu's Avatar
These figures are generally accepted by the surveyors. You might check "osmosis treatment" or "humidity meters" or combination on google. The figures are from my humidity meters users manual.
Only humidity is not the only measure for osmosis. A good surveyor will check the hull with the meter and by a small hammer.
Is it normal for the bowl to not fill? jarcher Gear & Maintenance 19 06-11-2009 12:04 PM
Is this normal rake davidpm General Discussion (sailing related) 25 09-29-2008 09:29 PM
Situation normal... cardiacpaul Off Topic 81 09-27-2007 01:31 PM
Humidity PBzeer Living Aboard 2 05-27-2006 10:23 PM
Humidity Control shall Gear & Maintenance 0 03-17-2003 04:48 PM
