Like Tree2Likes
  #21 (permalink)
Old 01-02-2012
paul323 is on a distinguished road
Wow. Just wow.
  #22 (permalink)
Old 01-02-2012
rhr1956's Avatar
rhr1956 is on a distinguished road
After assembling my cockpit grate by gluing and using a finish nailer, I put three coats of clear epoxy over top and bottom to seal it. Then followed up with three coats of spar varnish. At the same time I was making the grate, I made new mahogany handrails for the cabintop and refinished the mahogany trim around the companionway. I DID NOT put any epoxy on those items...just spar varnish..several coats. Result...the grate looks brand new after one year in Texas sun. The varnish only items will need a touch-up this spring.
  #23 (permalink)
Old 01-02-2012
mgiguere is on a distinguished road
After trying everything on our wood (varnish, cetol, etc, etc), the best stuff is Australian Timber Oil (Cabot Stains | Cabot). Other oils carbonize, but this has a different base and is water soluble, and is an oil and is relatively easily to apply. It's not marketed as a "marine" product, we just buy it at Lowe's. Just re-oil once/year to maintain.
  #24 (permalink)
Old 01-02-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by RichH View Post
Cetol is essentially a clear, moderately pigmented (ferrous oxide) enamel that eventually cracks upon 'build up'. .... its a royal ass-pain to remove.
Many of the 'modern' coatings (Bristol, Honey Teak, Smith & Co. etc. etc. use varying % of ferrous oxide as their UV blockers but the higher the % of ferrous oxide the less transparency of the coating which 'hides' the beauty of the wood grain ... and are typically co-polymers of urethane and acrylic or an 'epoxide' hence the 'mega-gloss'. Original Cetol is similar to a 'weak' brown enamel 'paint'.
Its the UV blocking that protects against the destruction of the surface wood cells that makes the 'modern' coatings so long lasting. I use Honey Teak (very expensive) applied 'thick' and the base coat lasts upwards of 10-12 years, a quick yearly or every two year maintenance clear coat is needed .... looks 'almost' like a prime varnish job and can be 'power-buffed' (to develop the glowing iridescent 'patina' of the wood cells) and doesnt look like 'paint'.
C'mon Rich - tell us what you REALLY think of Cetol.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
  #25 (permalink)
Old 01-02-2012
SloopJonB's Avatar
I too would rate a prime varnish job as the ultimate, especially when its 'finished' to perfection (top sprayed, hand rubbed, and then polished etc.) .... too bad that life is too short to be a slave to varnish. Unless the wood is totally sealed vs. moisture ultimately the combo of moisture migration through the wood and UV is going to kill varnish.
Ive posted this before .... a 10+ year old Honey Teak job ... Id rather be sailing.
You didn't mention that using Honey Teak leaves you enough time to keep your exterior bronze polished like gold!
  #26 (permalink)
Old 01-02-2012
RichH's Avatar
RichH will become famous soon enough
mmmmm. that bronze was mirror polished with jewelers rouge applied onto high speed fabric wheels then had 4+ coats of HT clear applied ... such will last about 4-5 years. Power tools are your friends, even on boats.
  #27 (permalink)
Old 01-02-2012
Parley is on a distinguished road
Tried an experiment back on San Francisco bay with a buddy who owned a sister boat to my c27. He used Bristol Finish. I used 3-4 coats clear epoxy (1'st 2 coats thinned); then 3-4 coats clear 2-part polyurethane. My buddy was done soon and it was gorgeous. I took much, much longer (did I say much?). Epoxy/poly result: stunning. The epoxy/poly lasted over 2 yrs. (then light sand & addit coat, just because - didn't need it). Bristol needed recoating in a year. That said, we had a neighbor in an old Choey Lee with stunning exterior teak. We had to inquire. It was 4 yrs old. Yup, Honey Teak.
Chuck
"A Small Sailing Craft is not only Beautiful, it is Seductive and Full of Strange Promise and the Hint of Trouble"
E.B. White; "The Sea and the Wind that Blows"
  #28 (permalink)
Old 01-02-2012
SloopJonB's Avatar
Rich, tell me more. What tool did you use? A Dremel type with the hardware in place or a buffing wheel on the dismounted hardware? What RPM?
I have a long shaft polisher - like a bench grinder with long arms. It runs off a 1725 1/2 horse Baldor. I've done a lot of polishing & buffing of brass, bronze, aluminium & S/S. I get great results using the coarser polishes - green, tripoli, white etc but I've never been able to get rouge to work properly on it. I have a 10" loose wheel specifically for that stage of buffing but when I use rouge on it I just get black streaks of compound on the workpiece.
Can you advise where I'm going wrong?
  #29 (permalink)
Old 01-02-2012
I have had great success with rouge, using a variety of tools including an electric drill (!) and a drill press(!!). They key for me was having the correct buffing wheel, which is dedicated to rouge. In fact, I have a range of buffing wheels ("mops"), each used for a specific grade of polish; they are easy to swap out as they screw into a conical threaded "hub". For rouge I use a very soft mop called "swansdown", sold in UK and Australia, made of calico...
  #30 (permalink)
Old 01-02-2012
RichH's Avatar
It makes a huge difference if the bronze has verdigris on it or not, rouge will never work with green verdigris present. To remove verdigris (or even the brown copper oxide) soak the part in citric acid (lemon juice if you cant get citric) .... If you cant remove the part soak the citric in absorbent cotton, apply and cover with saran wrap ... it does take some time to dissolve the verdigris.
Then, sand down to remove pits, roughness, etc. I prefer the 3M face discs made with their abrasive 'purple and green' pad abrasive. Hand sand down with 300-->100 grit emory; down to 600 W&D, then polish with jewelers rouge. You can use "Flitz" on the final polish.
Yes I use hand drills, and dremels with rotating fabric wheels on the non-removable parts and just a 'bench grinder' with cloth polishing wheels if the part is removable.
If possible, the part should be entirely coated as if you dont the oxidation will propagate from the 'backside' through screw/boltholes, etc. after a few years. My next trial/attempt with removable parts will be heavy clear 'powder coating' after mirror polishing.
Varnish stiffwind Gear & Maintenance 1 04-12-2011 11:20 PM
How Do You Get Varnish Off lofty22810 Gear & Maintenance 6 12-13-2008 12:51 AM
Varnish? Ronbye Gear & Maintenance 34 07-15-2006 12:41 AM
Varnish NewsReader Sabre 0 07-11-2006 08:15 PM
Varnish RichardElliott Gear & Maintenance 1 01-13-2005 02:42 PM
