Like Tree2Likes
Old 01-01-2012
Hookturn's Avatar
Hookturn is on a distinguished road
How much varnish?
I have a dinghy with a 20' wooden mast (spruce). I took it down to bare wood and am now varnishing it. It is an unstayed and very bendy mast. Should I be worried about too much varnish on it? Just wondering if I can overdo the varnish and maybe how many coats is ideal.
Thanks for any advice or input!
Old 01-01-2012
Squidd's Avatar
Tacky yet Unrefined
Squidd is on a distinguished road
Generally 3 coats with light sanding between ... 4 is ok...
Too many coats will get too thick and crack with loss of protection.
"Might as well cast off...If anything bad is gonna happen...It's gonna happen out there..."
"Captin Ron"
Old 01-01-2012
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
A good brightwork schedule is To start thin and sand between coats. I like to use 220 grit on the first couple of coats, then 320-400 grit paper and wet sand on the remaining 4- 6 coats.
Personally, I thin the first coat by 25%, the next coat by 20%, the third coat by 15%, 4th cat by 10%, 5th by 5% and the last coats virtually unthinned. Rebecca Wittman recommends a ten coat varnish schedule. Others recommend 6. I like a happy medium- 8. However, I sail in a seasonal fresh-water northern environment. In a southern saltwater region with a boat in water year round, I'd go 10-12 coats. Yeah, it's more time consuming but it beats doing it twice as often.
3 coats is fine for interior work, but not for a mast.
It's 5 o'clock somewhere:
Old 01-01-2012
Squidd's Avatar
Tacky yet Unrefined
My can of Spar Varnish says "Do Not Thin" right on the label..
"Captin Ron"
Old 01-01-2012
Then you might want to buy better varnish.
Old 01-01-2012
Hookturn's Avatar
If i use 10 coats should i worry about it cracking with the bend i get in the mast? I don't mind lots of coats. I just don't wanna do it again because i put too much on.
Old 01-01-2012
Rangernewell's Avatar
Rangernewell is on a distinguished road
Send a message via Yahoo to Rangernewell
I can't say for sure for a mast....Cracking due to flexing is possible. I alway use 6 coats minimum on all exterior wood
Old 01-01-2012
b40Ibis is on a distinguished road
I would do 4 coats to begin with, this gives you a good foundation. Depending on your local climate and or exposure, add 2 coats either once or twice a year. Of course with all the sanding and thinning as others have mentioned.
Old 01-01-2012
With the thinning and sanding schedule previously outlined, you won't have a cracking problem.
Old 01-01-2012
The fact that you have to recoat once or twice a year should tell you that 4 coats isn't enough. If you do 8 coats, you don't have to add two coats once or twice a year. You have to add one coat every two years.
More work now always means less work later when it comes to brightwork.
Damn, it's always tempting to cheat, though. I get done with coat number 3 or 4 look at the shine, and say to myself, "that's good enough, isn't it?"
Then I look at other boats, and the same people doing the same thing year after year, and grumbling about how they have to varnish year after year, and realize that good enough isn't either good or enough.
Sigh.
Don't even get me started on the blasphemy of cetol.
Varnish stiffwind Gear & Maintenance 1 04-12-2011 11:20 PM
How Do You Get Varnish Off lofty22810 Gear & Maintenance 6 12-13-2008 12:51 AM
Varnish? Ronbye Gear & Maintenance 34 07-15-2006 12:41 AM
Varnish NewsReader Sabre 0 07-11-2006 08:15 PM
Varnish RichardElliott Gear & Maintenance 1 01-13-2005 02:42 PM
