Like Tree1Likes
  • 1 Post By RichH
  #1
Old 01-05-2012
UsailIbail! is on a distinguished road
Emergency triage for sails. Advice to save them?
I purchased a 42' 1980 steel sailboat in Florida a couple of months ago and it has arrived at my home in Vermont recently. I am working on minimizing damages due to past neglect and am now easing the boat into a healthy state of storage while I begin a full refitting in earnest. The boat is in pretty rough shape now but an excellent candidate for a full restoration.
Question; as I am just starting to assess the sails I have come across this condition that I think will be prevalent on all of the sails. The bronze hanks have corroded a bit and now have the typical bluish/whitish powder on them. They are sticky to open but they all open. The grommets that the hanks run through in the sail have the same condition. What is the best way to treat this before I wash the sails and dry for long term storage? I do not want to involve a sailmaker at this point. I just want to store the sails for now in a clean condition. If I bend the bronze tabs on the hanks to ease them off of the sail for cleaning will I be able to re bend them on or do you think they will break... that would be bend #3 on each hank.
Second question; the stainless steel tack and clew grommets were put away salty and are corroded and have stained the sails in a few places. Any advice to treat these spots on the sail and on the stainless? I think that any acid solution on the stainless would destroy the sail material.
Thanks for your help.
Jay
the photos below were taken 15 years ago... the boat is in much rougher shape now!
Emergency triage for sails. Advice to save them?-maverick1.jpg   Emergency triage for sails. Advice to save them?-maverick3.jpg
  #2
Old 01-05-2012
RichH's Avatar
RichH will become famous soon enough
If DACRON sails and if you're going to 'wash' the sails anyway .... lemon juice will dissolve the 'verdigris' (various complex forms of copper acetate/oxide) on the bronze hanks ... just 'partition' the hanks away from the sail cloth with plastic film (saran, etc) when 'soaking' in the lemon juice so that the loosened verdigris doesnt 'transfer' & become embedded in the cloth. Be sure to rinse well.
For the staining from the ss (???) grommets, its probably 'rust' from the ss .... then a soak with oxalic acid (from a paint/hardware store - sold as dry crystals) will quickly remove any 'rust' staining (plus tannin staining). Usually its best to 'wash' the sails with a caustic/alkaline detergent to remove grease/oil/fungus before bleaching with oxalic. Again be sure to rinse well to remove any oxalic acid. Be sure to use 'protection' when using oxalic acid ... absorbs through skin quickly and can do great harm to your kidneys. Oxalic Acid is usually available in non-eco-frenzy, non-chemophobic states.
Again if the sails are woven polyester/dacron, such is quite stable and resistant to most 'inorganic' chemicals and solvents. .... not so with many 'organic' solvents, etc. (gasoline, kerosene, MEK, 'paint thinner', etc. etc.) ... Avoid! do websearch for "chemical compatibility" + polyester if in doubt.
jackdale likes this.
  #3
Old 01-05-2012
SOVT is on a distinguished road
Out of curiosity where are you in Vermont? We trucked my Fuji 36 up to Bennington this year for a retrofit.
  #4
Old 01-05-2012
Ha! It must be just as tricky to find an empty mooring in Bennington as it is in Norwich! Normally I would have to ask why ANYONE would have such a boat so far in-state but truth is.... I am probably the only other person in this state that can answer that question. Besides you of course!
Here is a link of the delivery of my newest project. Generally the boat is in excellent condition. But I clearly have very much work to do - which is just fine with me. I am crazy about boats. At least that is what my wife tells me... but I think we interpret the same sentence quite differently.
Jay
Sail on!
Maverick Arrives! - YouTube
  #5
Old 01-05-2012
RobGallagher's Avatar
HANUMAN
RobGallagher is on a distinguished road
Cool video. Keep us updated with your progress!
  #6
Old 01-06-2012
mitiempo's Avatar
Nice video. What design is Maverick and who was the builder?
Brian
  #7
Old 01-06-2012
The designer is Henk Tingen. This particular design was one of his last. It was built by the Kompier yard and finished privately. The steel has held up very well except for the teak decking over steel. That was laid before people realized it's inherent faults. As such, salt water crept under some of the teak and caused much of the steel to fail, which in turn caused significant leaking inside the boat. I am now learning of the extent of the rust and am pleased to have learned that after I cleaned off the deepest mold I have ever run into, much of the interior can be saved. It will be a beautiful boat when the refit is complete.... which I am taking my time with.
Jay
Sail on!
You may post attachments
You may edit your posts
Advice on Keeping Sails Nice carl762 Gear & Maintenance 16 10-25-2010 04:07 PM
Need advice regarding compensation for stained sails patrickstickler General Discussion (sailing related) 18 02-22-2009 10:25 AM
Buying new sails, need advice ajf10 General Discussion (sailing related) 31 01-22-2009 11:00 PM
need columbia 22 sails advice rudderless22 Columbia & Coronado 2 11-11-2008 08:33 PM
SPLASH! Save the Harbor/Save the Bay Newsletter NewsReader Mass Bay Sailors 0 06-15-2006 06:15 PM
SEO by vBSEO 3.6.1
