Old 01-06-2012
chartscharts is on a distinguished road
Adhesive of choice in this situation?
Happy New Year!
I need to bond a piece of metal to a piece of hard rubber. It might get some light spray now and then but mostly dry. Needs to be a pretty strong bond.
Epoxy? Any particular kind recommended?
5200? I wouldn't think this but I've heard tell of people using it to glue anything and everything. So I'm willing to try it if it bonds well.
-Charts
Old 01-06-2012
jrd22's Avatar
Courtney the Dancer
What's it going to do, how much of a load are you going to put on the bond?
I would lean toward 5200 rather than any kind of an epoxy, but not knowing what the "hard rubber" actually is makes it difficult to know.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-06-2012
Rockter will become famous soon enough
chart :
You are going to need something flexible, methinks. Epoxy tends to be a hard animal and does not like dissimilar stiffnesses. Try to set it up so that you avoid peeling loads. Direct and shear stresses are better tolerated.
Old 01-07-2012
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Epoxy is likely to be brittle without some kind of additive.
5200 is what I would use.
Old 01-07-2012
Sea Diamond is on a distinguished road
If the joint needs to remain a bit flexible, you might consider 4200 rather than 5200. Also, I believe you need to apply some pressure (clamping etc.) for a good bond.
Old 01-07-2012
Ulladh is on a distinguished road
What type of load;
Compression, pulling, twisting?
What type of metal;
Stainless steel, bronze, aluminum,....
What type of hard rubber;
real rubber, synthetic rubber?
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Old 01-07-2012
Minnewaska will become famous soon enough
Is this lifesaving adhesion or decorative? The 5200/4200 recommendations are where my head is generically, but there are not enough details to give good advice.
Jeanneau 54DS
Old 01-07-2012
MarkSF is on a distinguished road
I did a quick search and found this :
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
I also recently used some flexible epoxy for plastic, on my hypalon dinghy :
Marine Tex, epoxy resin, adhesives, silicone grease, engine treatment, cleaner, repair, bond, fill, seal, fiberglass, aluminum, plastics, Starboard, wood
Both those products state they will bond rubber and metal.
Bristol 31.1
Delicate situation Pub911 Gear & Maintenance 10 12-31-2009 03:33 PM
Horrible situation... PalmettoSailor General Discussion (sailing related) 115 07-18-2009 10:08 PM
Pan Pan - I am in a situation and could use some advice. SchoonerMISTRESS General Discussion (sailing related) 85 05-22-2008 07:27 PM
Overheat situation Valiente Gear & Maintenance 12 07-09-2007 09:30 PM
no winch situation tappers Gear & Maintenance 0 08-05-2002 04:37 PM
