01-09-2012
I have one in my camper, and have never had any issues other than the height thing. Easy to fix with a grate in the shower pan. As was mentioned in another thread, you could leave the water off if it only gets used for #1 and leave the dry bowl. If you are really concerned, you could forego the water hookup altogether and use a squirt bottle to rinse the bowl after use. I use a 5gal pail to rinse the whole system when I dump. After 15gals of rinse water (5 per rinse), I can see the bottom of the tank is clean. No smell issues, no problems at all. I'd give serious consideration to one on my boat if the porta-potty wasn't so convenient.
