01-12-2012
Picking the "right" line size
The line should feel OK when handling, fit OK through the clutches without slipping under load, and hold without slipping in your ST winches.
Strength, per se, is not an issue on any modern line.
We use 5/16" T-900 (an old school hi tech line) for all halyards on our 34 footer, for instance. It passes the above tests.
(Note further that most any modern low-stretch line in those sizes has enough strength to substitute for any of the ss shrouds on your boat!)
Our mainsheet and genny sheets are 1/2" , IIRC.
L
