Old 01-13-2012
JasonBewley is on a distinguished road
Rubberized undercoating over rub rail
I read an article on using using paintable rubberized undercoating over rub rails to better seal the hull deck joint. Has anyone tried this? Does it hold up well, or crack and peel? I assume it would have a course finish even.if painted. Would it be considered cheap insurance against a leaky joint, or just hill-billy? Any thoughts or comments would be appreciated.
“The person who goes farthest is generally the one who is willing to do and dare. The sure-thing boat never gets far from shore.” Dale Carnegie-
Old 01-14-2012
tommays's Avatar
just hill-billy
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-14-2012
ewoden's Avatar
ewoden is on a distinguished road
Being a hill-billy myself...
Probably wouldn't use rubberized undercoating. Now Rhinoliner or Herculiner...those materials are the bomb when it comes to sealing and abrasion resistance and super UV resistance. Rhino can even be color matched. You put that stuff on however, and no chemical stripper is going to ever take it off, you will be sanding/grinding to remove if you change your mind later.
A ship in harbor is safe, but that is not what ships are built for.
William Shedd
Old 01-14-2012
Smile
Found an epoxy blend called Gator-Guard that looks perfect for this application. It comes in white, has the elastic & adherence properties of epoxy, but is blended for UV stability. Permanent indeed; I better remember to replace those screws with thru-bolts BEFORE its applied
use of toe rail.. sweetdreamyamaha Seamanship 13 08-15-2010 02:21 PM
rub rail ncsc Cal 14 09-22-2009 05:15 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
New Toe Rail Bermuda30 Gear & Maintenance 1 08-14-2008 06:36 PM
Toe Rail And Rub Rail C&c FRANK PALERMO General Discussion (sailing related) 1 10-08-2006 09:14 PM
