Like Tree1Likes
Old 01-14-2012
sealover is on a distinguished road
Paint/Coating for leaky aluminum dinghy?
Full disclosure: It's not really a dinghy. I'm technically a power boater... I have a 1950's (?) 14' aluminum row boat that I clamp a 4 HP outboard onto and go crabbing. Except it leaks like a wicker basket. I caulked every last rivet and seam from the outside and and it still takes on water. I'd like to paint/coat it with something (inside or out, or both) that will reduce the amount of water coming in.
ideally whatever this miracle product is, it will:
1. cost well less than the $100 the boat is worth
2. be of a light color if it's going inside of the boat so it doesn't cook me and the crabs on a sunny July day. (otherwise I'd use that black screen-door-in-a-boat stuff on TV?)
3. not require scuff sanding around all the obstructions inside or removing the globs of silicone caulk on the outside.
4. hold up to being beached on rocky/sandy shores, being scratched by metal crab traps, and survive on a boat that is stored upside down on it's trailer under a walnut tree when not in use.
Yes I'm asking for a lot. But I'll concede: I'll touch it up every year if whatever it is will survive in a can in my garage for multiple years, and I will pressure wash the heck out of the boat and let it dry for weeks indoors before applying. And I really don't care what it looks like.
I've looked on various other forums and have received all sorts of suggestions that don't meet any of the above (Why yes, I'd love to have it Rhino-Lined but that will cost more than the boat, trailer, motor AND the car I pull it with...) so I thought I'd take it to my sailing bretheren here. We seem to be a more realistic, thrifty bunch.
Remember, this is a $100 aluminum row boat that was made when there were only 48 states. It's really not worth much time or effort. I just want to get a few more years out of it.
Thanks!
Keep the expenses low and the good times high.
S/V Over Easy
Venture 17
PA Freshwater / Chesapeake
Old 01-14-2012
CaptainForce's Avatar
I think I have your answer. Empty one entire caulking tube of the white 3M 5200 into a paint can an thin it to a brushable, yet still fairly thick "paint" with acetone. Adherence should be good if you have wiped off the surface with the acetone first. Take care and joy, Aythya crew
Old 01-14-2012
Seriously? That sounds easy enough. Never thought of making my own product. Maybe I'll do that on the inside and house paint on the outside (that's made to go on aluminum trim/siding, right?)
S/V Over Easy
Venture 17
Old 01-14-2012
celenoglu's Avatar
celenoglu is on a distinguished road
Aluminum is difficult to coat. It needs a special primer for painting.
Old 01-14-2012
When we painted our mast years back we were advised to wash it down with vinegar before painting (a mild acid wash).. we did and the paint still looked fine 10 years on.
FWIW any sealant/coating will probably work better on the outside, as long as whatever you use won't get worn off by passing water. A membrane preventing water from getting into the rivet cavity will be better than an inner membrane dealing with water that's already made it through that gap.
1984 Fast/Nicholson 345
Old 01-14-2012
tommays's Avatar
Use Gluvit on aluminum fishing boats to repair leaky aluminum seams and rivets.
Gluvit seems to have had success
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-14-2012
ewoden's Avatar
ewoden is on a distinguished road
Soda or shell blast the interior, mild acetic acid wash to etch, haul over to local truck bedliner place for a spray of Rhino or buy a gallon of Duron Herculiner roller and a detail brush.
SloopJonB likes this.
A ship in harbor is safe, but that is not what ships are built for.
William Shedd
Old 01-14-2012
jrd22's Avatar
Courtney the Dancer
Go to Home Depot, Lowes, etc and get a gallon or five of the goop used on aluminum roofs, RV's, etc. Slop it on the outside of the boat, reapply as necessary. I would try to get as much of the silicone caulk off the seams first and wipe down with acetone and stainless steel wool, almost impossible to get anything to stick after you've contaminated it with silicone.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 02-19-2012
Follow up- someone else suggested a big caulk tube of 5200, but said "heat it first, it'll thin out and last longer. He slides the tube up the tailpipe of his running pickup truck. How's that for ingenious!
S/V Over Easy
Venture 17
Old 02-19-2012
deniseO30's Avatar
Lies about her age
Did you ever think of having a friend help you block and hammer the rivets?
Engine: To paint or not to paint aluminum and bronze parts dennisvetter Gear & Maintenance 4 03-19-2011 10:06 AM
coating aluminum spars? ChuckA Gear & Maintenance 19 03-22-2010 01:21 PM
Topside paint /refinishing/Coating charliea Gear & Maintenance 6 12-24-2009 04:46 PM
dinghy bottom coating results huguley3 Gear & Maintenance 4 08-26-2009 05:18 PM
Prop Coating with Vivid Paint lancelot9898 Gear & Maintenance 6 04-21-2009 02:20 PM
