Old 01-14-2012
JawsB40 is on a distinguished road
Boot between shaft log and packing
I am trying to install an Aqua Drive on my B40. The distance between the shaft seal and transmission is limited. Is there a reason that the rubber boot is so long adding a couple inches to the seal position? Ultimately I am considering having a new shaft log machined with threads and a packing nut inboard to give me the clearance I need. I am trying to leave enough room to renew the packing as necessary. Or I could incorporate a Tides Seal if water circulation is the issue. I have to be inventive here because my new Yanmar is difficult to align due the the hull design.
JAWS
Rudder shaft packing on a 34 johnharch Pacific Seacraft 28 12-03-2010 09:24 PM
prop shaft packing mrtibbs Islander 0 11-16-2008 02:42 PM
shaft packing sdbic Gear & Maintenance 8 05-10-2007 09:48 AM
C-27 shaft packing seized on shaft? CellNav Gear & Maintenance 1 05-08-2007 02:55 AM
Shaft Packing f_cousin Gear & Maintenance 1 07-27-2003 07:10 AM
