Like Tree1Likes
  • 1 Post By killarney_sailor
Old 01-15-2012
pogosmoke is on a distinguished road
Gunwhale leaks help.
I have 82 C&C 25 and I have water collecting on the ledges on both sides of the forward vberth also water collects in the storge underneath the vberth. I suspect it may be the gunwhale where it attached the hull to the deck? I havent seen the leak but it is pretty bad. A couple of bad rains had went by and went to check on the boat the the entire vberth cusions and linen were soaked and had molded. The gunwhale is fiberglass i think a dark color and is screwed down. Can I just epoxy along the seams? Do I have to take it apart? What should I do?
Old 01-15-2012
itsaboat's Avatar
itsaboat is on a distinguished road
Are you sure it is the gunwale? I'm not familiar with the C&C, but my boat has a drain from the anchor locker that is just above the v-berth. If I saw water, I would check that first. Also, I just bought Don Casey's Sailboat Repair book Amazon.com: Don Casey's Complete Illustrated Sailboat Maintenance Manual: Including Inspecting the Aging Sailboat, Sailboat Hull and Deck Repair, Sailboat Refinishing, Sailbo (9780071462846): Don Casey: Books
It covers most everything.
Old 01-15-2012
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
I assume that the C&C hull-deck joint is throughbolted with a mastic compound to keep the water out. Feel around where the hull and deck join and you should notice that it is slightly sticky. You might try tightening the bolts that go through the toe rail, deck and hull flange. Much easier with two people than one. Person outside holds the bolt in position with a scewdriver and the person inside tightens the nut. Don't overtighten - you don't want to squeeze out all of the bedding compound. You may find that some of the nuts are backed off just a bit over time and this is allowing the leak.
Faster likes this.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
H22 Leaks Carina22 Hunter 1 07-30-2011 07:04 PM
Hull leaks chasb47 Gear & Maintenance 10 07-17-2011 11:15 PM
c-13 ls leaks thrillero8 Chrysler 3 04-01-2010 07:14 AM
Plugging The Leaks... backcreeksailor Gear & Maintenance 2 04-20-2009 02:10 PM
OMG my boat leaks! huguley3 Gear & Maintenance 21 03-25-2009 05:45 PM
