Harken Radials - Page 2 - SailNet Community
post #11 of 16 Old 01-25-2012 Thread Starter
Jack, when you're single-handed and tacking, that's kind of hard to do .
Hardening overrides are mostly due to incorrect mounting of the winch, as mentioned by SJB, and having too many coils on when pulling fast on a sheet, as you mentioned.
Still, would be good to know if anyone has had experience either way (easing or hardening) with these particular winches.
Umeds? is offline
post #12 of 16 Old 02-20-2012 Thread Starter
Rather than get all frustrated after getting the winches and not being happy with them, i sent the Radials back and got me a sweet pair of Andersens. 'Figured it's one piece of kit that shouldn't be skimped on.
Before:
After:
Umeds? is offline
post #13 of 16 Old 02-20-2012
Senior Moment Member
SloopJonB's Avatar
Before:
After:
Outstanding decision. I'm not a big fan of Harken gear. I've had some and while it worked well, it always looked a bit "cheap" to me. The difference between those Harkens and Andersens really makes my point IMO.
Take care of those Andersens and they will outlive your grandchildren.
SloopJonB is offline
post #14 of 16 Old 02-21-2012
I don't discuss my member
zz4gta's Avatar
Harken gear isn't cheap, they're just using modern materials instead of technology that is over 100 years old. Harken also deliberately removes weight were it is not needed. Anderson doesn't have any interest in light weight options. They are very nice winches, but extremely heavy.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #15 of 16 Old 02-21-2012
SloopJonB's Avatar
Believe me, I KNOW it's not cheap. I just think a lot of it LOOKS cheap - take the stainless top of that winch - it looks like a sheetmetal stamping while the Andersens look like they were carved from a block of Stainless. I like things like winches to be heavy - it's reassuring. I have always thought worrying about 10 or 15 lbs on a 10K or 20K Lb boat to be a bit academic anyway - it you're THAT worried about weight, put yourself and the crew on a diet and leave the beer ashore.
Of course you aren't going to find high tech deadeyes & lanyards on my boat either.
post #16 of 16 Old 02-21-2012 Thread Starter
They are using modern materials ON technology that is over 100 years old. I'm all for inovation and evolution. I'm also of the opinion that "if it ain't broke, don't fix it". The Andersen products seem like they will stand the test of time, and for a cruising sailor, who wants a trustworthy and quality product, they seem to me to be the best option. They are not EXTREMELY heavy, more like: they are worth their weight!
I was convinced by Harken's marketing that the new Radials were a quality product, until i did further research on the forums and found that some people complained about certain types of lines slipping. Then i realized that the winches are made in Italy which to me represents a lesser quality manufacturing process (slightly better than "Made in China"). Finally, i realized that the price of the winches were CONSIDERABLY cheaper than other makes, not only the Andersens, which are of course the most expensive.
All this made me realize that i was skimping on the one piece of gear that should be the most trustworthy of all on a sailboat! If you can't winch in your sheets and halyards, you can't sail effectively. And if you can't sail effectively, you might as well not sail at all. Hence sending back the Harkens and ordering the Andersens (which i got for a great price btw: Andersen Winch No.40ST - 2 Speed).
Something has to be said in defence of quality gear and how unfortunately more and more manufacturers are willing to compromise on quality for the sake of more revenue (yes, i am talking about Rocna here too...).
Umeds? is offline
Harken Traveller on a C&C 32 Kiltmadoc Gear & Maintenance 10 07-18-2010 05:47 PM
Harken MK II unit 1 ROSA Gear & Maintenance 15 06-12-2010 11:43 PM
Harken bat car system docrn Gear & Maintenance 0 08-03-2009 01:18 AM
harken shoes ianbass Gear & Maintenance 1 03-09-2008 11:19 PM
Harken Magic Box (help!) chenness Gear & Maintenance 3 06-03-2002 08:21 PM
