Like Tree4Likes
Old 01-18-2012
VIC26 is on a distinguished road
Removing vinyl from life line
Anybody have any advise on removing vinyl from life lines? This is a renovation and I would like to remove old, cracked covering to see the condition of the lines. So far this is going very slowly. I would like to reuse if they are in good condition, with no vinyl.
Old 01-18-2012
Mark1948 is on a distinguished road
I removed mine this past summer from my C-27. I used a knife blade that I could carefully guide with both hands, like a spoke shave and just cut one side off and pealed the remaining layer. subsequently used metal polish on the cable to clean it up. It did not take all that long, being brittle. You need to be careful not to cut into the wire. All in all not that difficult and looks better.
Old 01-18-2012
Jeff_H's Avatar
Super Moderator
The easiest way to remove vinyl from lifelines is to remove the entire lifeline and replace the entire lifeline with new uncoated wirerope. Seriously, by the time the vinyl is shot, typically the wirerope is also shot and dangerous to keep. Current standards discourage the use of vinyl covered lifelines.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 01-18-2012
jackdale's Avatar
jackdale will become famous soon enough
ISAF has also approved single braid Dyneema for lifelines.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 01-18-2012
patrscoe's Avatar
patrscoe is on a distinguished road
I was thinking of doing the same thing but as I removed the about 10' vinyl coating, I saw two potential eroded areas, not a lot, but some. I ended up replacing my coated lifelines with uncoated 1/4" (although 3/16" would be okay), 1x19 ss 316 wire rope. I reused all loose hardware but installed all new swage studs. Took less then a day, in my garage and was fairly easy.
Also you will be removing vinyl on 7x7 wire rope and if you go bare, the recommended wire is 1x19.
Good luck.
Patrick
S2 11.0A
Chesapeake Bay, Va
Old 01-18-2012
Semper Fidelis
mxracer19 is on a distinguished road
I say take a razor blade scraper and just run it down the length of the wire flat like youre scraping paint. Keep it at a low angle and it wont cut in. When youre done take a cotton ball and wrap it around the bare lifeline and run it along the wire in one direction. Broken strands will catch the cotton and highlight areas of concern. Repeat the process in the opposite direction after inspecting to catch broken wires facing the other way.
Use symbal polish on the wire afterwards. Symbal polish looks like oily cotton in a tin can. Its used to clean symbals (No sht) on drumsets. Wad it up around the wire and rub it back and forth a few times. She'll clean right up. You can find symbal polish at any major music store. It's also used to polish guitar frets.
Lastly, take pictures and post an article on here documenting what you did so others may benefit.
-Matt
-S/V Far Niente
Old 01-18-2012
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Go to dyneema, and be done with it in 2 hours.
Merit 25 # 764 "Audrey"
Old 01-18-2012
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
What are the disadvantages of Dynema?
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 01-18-2012
mitiempo's Avatar
UV and abrasion.
Brian
Old 01-19-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by mitiempo View Post
UV and abrasion.
Fairly serious disadvantages for something that spends its life in the sun being rubbed against.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
VYNIL LIFE-LINE COVER Replacements......?? nicholas829 Gear & Maintenance 1 03-31-2009 11:18 AM
MiraCosta LIFE group hears stories about life at sea - San Diego Union Tribune NewsReader News Feeds 0 04-19-2007 06:15 AM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 01:38 PM
Life Jacket, Life Vest, PFD....Recommendations micetic Gear & Maintenance 14 02-18-2007 10:05 AM
life line stanchions HerbertFriedman Gear & Maintenance 1 12-09-2001 06:01 PM
