01-21-2012
Senior Moment Member
Originally Posted by rhr1956
I need to take care of a soft deck core under the bow pulpit mounting flanges. I will be cutting the deck and core using a hole saw, then refilling the hole and touching up with a little paint before re-mounting the pulpit.
1. Epoxy or Polyester?
2. Should I use chopped glass or something else as a filler?
3. Can I fill the hole completely in one shot, or should I layer it in a few steps?
Thanks for any advice.
Epoxy. The only reason to ever use polyester for anything is cost. It is inferior to epoxy in every way but price.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
