01-22-2012
AFAIK the newer bigger Bendy's have carbon-fiber rudder shafts and composite rudders--no metal armature, no stianless post, specifically because any rudder with a stainless post and a metal armature is simply a failure waiting for the right time to happen.
Apparently you can't bond and seal the stainless post to the grp rudder in any real long-term way. So normal thermal contractions, water pressure, a gentle bump, anything can open a hairline and then water will seep in and over the next 5-20 years it will rust out the armature, decay the foam, and cause a rudder loss.
Draining the water every year is like letting puss out of a wound--but not treating the infection itself. A stock rudder (cf or ss post) for a 35-40' OAL boat can run a fast six grand from the maker, delivered or not. And that'll fix it for another ten or 20 years.
A proper repair if there's water in the rudder? If you've got the skills, split it open, rebuild it, seal it back up. Very few shops fabricate rudders. Very few want to repair them. I give Bendy great credit for trying to use carbon fiber in order to avoid the stainless problem.
