Old 01-22-2012
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Hardare for Mounting Kyocera Solar Panel on Davits
Hey all, just bought a Kyocera 130 Watt solar panel. This is to upgrade our current Siemens 40 Watt panel. Can anyone recommend good hardware to use to affix it to our davits? I need to get some clamps or whatever is usually use for mounting. The panel is 56.1"x25.7"x2.3" and
26.8 lbs.
The 40 Watt panel is mounted on a 4"x1" hallow bar across the top of our davits. The bar also holds antennas on one side (cables go through the bar). I'm wondering if we can still use this bar or whether to invest in something else.
Here's a picture from my wind generator planning. The wind generator is in place just as designed here. I'd like the new, wider panel to be no closer to the transom of the boat, but to "stick out" further aft. The old panel is 12" wide, if I recall correctly.
Regards,
Brad
P.S. An option would be an easy pivot system so when the snow piles up in winter I don't have to worry. I don't need the pivot really, since I could make a "trailering transom saver" type support and put it in place in the winter. So something simpler is OK for now.
P.P.S. I'm moving the stern nav light to the back of the davits somewhere.
Old 01-23-2012
sea_hunter's Avatar
Senior Cruiser
sea_hunter is on a distinguished road
You'll find what you're looking for at wholesalesolar dot com.
"Water, water, everywhere, And all the boards did shrink;
Water, water, everywhere, Nor any drop to drink.
Old 01-23-2012
dory mate
alpatn@gmail.com is on a distinguished road
I would have 2 cross bars between davits. Have had good results using rail clamps & hardware pieces from west. Just were they have set screws we drill & tap into pipe. You can attach the panel to the bars by drilling 1/4 holes in bar and put a rubber washer between bar and panel scure with 1/4 20 machine screws with nylock nuts.
So if kyocera is the best solar panel manufacturer.. groundhog Gear & Maintenance 21 11-16-2011 01:36 AM
solar panel wire size (8 awg wont fit) and mounting question funjohnson Electrical Systems 5 06-05-2010 05:29 AM
Mounting solar panel on top of dodger hardware? SanDiegoChip Gear & Maintenance 14 03-05-2010 11:24 AM
Solar Panel mounting hardware GreatWhite Gear & Maintenance 9 01-01-2010 09:03 AM
Solar Panel Mounting On A Davit Freesail99 Gear & Maintenance 8 08-14-2007 02:22 PM
