Sealed lead-acid batteries - SailNet Community
post #1 of 5 Old 10-15-2003 Thread Starter
I''ve seen some of these at a trade show recently. any thoughts on their suitability for marine use?
sneuman is offline
post #2 of 5 Old 10-16-2003
my boat came with 13 sealed delco group 27 batteries.
so far no problems no maintenance.
fair winds,
eric
kimberlite is offline
post #3 of 5 Old 10-16-2003 Thread Starter
but are those gel? the ones i''m talking about are lead-acid - more bang for the buck but in their former incarnation neither maintenance free nor completely safe (they exhale hydrogen - ok if you have proper ventilation). The guy I talked to said there''s a small pump inside that periodically expels the h2 - he said maintenance-free lifetime would be 3-8 years depending on the battery and the application.
sneuman is offline
post #4 of 5 Old 10-16-2003
alot of these batteries will be distroyed if the charge voltage goes over 14 volts. it will cause them to boil and vent. so be very coutiouse.
obiec is offline
post #5 of 5 Old 10-16-2003
yes these are plain old delco lead acid batteries. I believe as does the boat manufacturer that you get the most bang for the buck with these. They are also available anywhere in the world.
my batery locker is sealed and vented to the outside.
eric
Use of AGM/Glass mat batteries santorinidon Gear & Maintenance 7 07-15-2006 01:59 AM
house batteries seac Gear & Maintenance 9 08-23-2004 05:28 AM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 06:41 PM
Batteries - Mixing Different Ah ken346 Gear & Maintenance 1 05-27-2001 12:59 PM
How to make and use a Leadline karlheinz Seamanship & Navigation 7 03-30-2001 02:38 PM
