Old 01-23-2012
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Which Manual Bilge Pump?
I need a manual bilge pump for my Montgomery 17.
I want to be able to operate it from the cockpit but I also want it to look somewhat decent. WM has one that I think fits the bill for placement and looks but I am not sure about the handle on it. Apparently the cover doubles also as the handle for the pump. Just by the looks of it I am not sure if this is a feasible handle or not.
Does anyone have experience with a pump like this? Any opinions?
JOHNSON PUMP Pump-blg at West Marine
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 01-23-2012
Brent Swain is on a distinguished road
Some are engineered to make sure you have no option but to use only their parts, and can't substitute anything. I weld up my own manual pumps out of scrap stainless. They are quite simple. Any good metal worker can easily make his own.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
Old 01-24-2012
mitiempo's Avatar
I don't think you need a custom built stainless pump on a 17' boat. But the one you linked to looks a bit strange to me - the handle design in particular.
This one may work well but where you will mount it may determine the type of pump. Whale Compac 50 Series Low Profile Bilge Pump
Brian
Old 01-25-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
On a boat that size, just carry your anchor and line in a five gallon pail. If you spring a leak, dump out the bucket and use it. If you want something to slurp up a bit of rain & spray, get one of those cheap plastic "Navy" draw pumps as well - about $15 or $20 IIRC.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 01-25-2012
aeventyr60 is on a distinguished road
Nothing better then a scared man and a bucket...
"Your dreams minus your doubts equals your net worth"
"Life favors the Fearless"
Old 01-25-2012
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Sorry for the hi-jack. Can this pump be mounted vertically as well as horizontally?
S/V Old Shoes
1973 Pearson 30 #255
Old 01-25-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
I doubt one of those little Johnson pumps would be very comfortable to use for more than a few strokes. I would opt for something with a more ergonomic handle. The Whale pump that mitiempo points out looks much better. Also, remember that for the same size hole a small boat will sink faster than a larger boat. Which calls into question whether on should always thing a small boat needs a small pump.
Old 01-25-2012
.... or woman!
I like the idea of the 'built in' handle.. nothing to lose - but I suspect that the difficulty in use mentioned above may well prove true. Certainly there's reduced leverage compared to the one that Brian posted.. for $20 difference it's probably the better choice.
1984 Fast/Nicholson 345
Old 01-25-2012
mitiempo's Avatar
Yes it can be mounted either way. My pump is similar and installed in the side of the cockpit footwell.
Brian
Old 01-25-2012
overbored's Avatar
overbored is on a distinguished road
that pump is the same type as the new Whale Smartbail it does not have the same output as the other pumps with a handle. 9gmp vs 17 gmp. it can be operated by hand or foot. advantage is you won't loose the handle. the bigger pump won't even put of 9 gpm if you can't find the handle
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
Manual Bilge Pump - Plastimo or Whale Quickstep192 General Discussion (sailing related) 2 10-17-2011 09:57 AM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
manual bilge pump billdre O'Day 1 05-19-2010 08:39 PM
Manual to Auto bilge pump RocktheBoat Gear & Maintenance 0 06-23-2009 07:44 AM
Manual Bilge Pump backcreeksailor Gear & Maintenance 13 04-18-2009 01:02 AM
