Like Tree4Likes
  #31 (permalink)
Old 02-03-2012
Maine Sail's Avatar
Originally Posted by mitiempo View Post
The shaft is firmly attached to the coupling and the coupling is bolted to the transmission. The transmission fluid has nothing to do with the electrical connection. You can check with a multimeter to confirm.
As Maine stated, unless there is a flexible coupling, which eliminates the metal to metal connection at the coupling the shaft brush isn't needed. If there is a flexible coupling a wire jumper from the transmission side to the shaft side can make the connection and is less hassle than a shaft brush.
I have yet to come across a single gear box that did not have continuity between the shaft and the engien block UNLESS it had a Drivesaver inserted between.
The ABYC considers the engine "ship ground" in most installations. This "ground/Earth" uses the shaft to get there... The only time a shaft brush should be needed is when the shaft is isolated via a Drivesaver or similar....
What I want to know is what "desk wonk" writes these articles? Did they forget about the bearings, shafts and metal to metal contact....??
mitiempo likes this.
______
-Maine Sail / CS-36T
  #32 (permalink)
Old 02-04-2012
L124C's Avatar
L124C is on a distinguished road
Get over it?
Originally Posted by sea_hunter View Post
You need to haul out to do the stuffing box properly. If there's a bearing or shaft issue, it's all problematic. There's nothing wrong with grounding the shaft with a brush. If it had been done in the first place this issue would have not been as traumatic. it's a boat get over it. Sometimes you have to pull without a moments notice; this is one of those times.
Yet, another country heard from! Kinda missed my point. I had decided to replace the stuffing box and have no problem hauling if I need to. In fact, I was fully prepared to haul if my diver said "Replace it in the water? Are you nuts?" Though, based on some of the responses, I was somewhat reluctant to even motor it to a yard! However, he said, "no big deal, see it all the time". I consider him conservative, he's not one to take short cuts or risks.
So, I'm simply bewildered by the variety of opinions and information I've received on a fairly basic issue. Everything from, "don't tap it, it might shatter and sink the boat" or "boats go forty years without a brush and don't look like this", or "if it had a brush, it wouldn't be this traumatic (I'm not "traumatized", just confused BTW)" or "put some grease on it, it'll be fine!".
As always, I'm grateful for the input. However, the range of these opinions, and other information I've obtained (The trany fluid theory didn't make sense to me BTW, but what do I know?!) is rather startling! I mean...we're not talking String Theory here!
So, thanks for identifying it as a "boat". I wasn't sure about that. However, please don't tell me to "get over it". Hauling when needed is prudent. Unnecessarily hauling is simply stupid! I'd just love to be on the hard and have the yard mechanic say "why are you replacing this?"
  #33 (permalink)
Old 02-08-2012
L124C's Avatar
Took out the Ohm meter. While the stuffing Box is conected to the motor, it doesn't appear to be a very strong connection. Think I'll bond it!
  #34 (permalink)
Old 02-08-2012
sea_hunter's Avatar
Senior Cruiser
sea_hunter is on a distinguished road
Good choice. I don't think I misunderstood you; it's all in the translation.
"Water, water, everywhere, And all the boards did shrink;
Water, water, everywhere, Nor any drop to drink.
  #35 (permalink)
Old 02-08-2012
tommays's Avatar
It makes no sense at all to me that your strut ,through hulls and other bronze parts are fine and the log is damaged as i have not seen damage without and electric issue on your boat or one close by or a hot dock issue
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #36 (permalink)
Old 02-08-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
We recently removed our bronze prop shaft for replacement as it was worn at the cutless bearing. Given that our boat was hauled (on the hard) we removed the 43 year old stuffing box which looked a bit like yours - maybe not quite as corroded looking.
We took the stuffing box home and used a wire wheel on it and it now looks like new (see pic below). We will be using most of the old components when we put the drive train back together with the exception of a new shaft log hose and a new cutless bearing.
What I'm getting at is perhaps you should try using a wire wheel drill attachment and see if you can clean up the metal on the stuffing box. My guess is that it is probably not as bad as some might think.
Of course, this is the last place you want to start an accidental leak in which case you will be hauling out, and fast. Work carefully, slowly and deliberately and you should be fine.
I didn't see if you had a drive saver in your set up. Do you? If so then the comments about grounding the shaft across the drive saver are on the mark.
pink prop! pasairinc Cal 10 09-19-2011 11:21 AM
Restoring shine to metal parts (cleats, port hole metal) saurav16 Gear & Maintenance 23 11-19-2008 05:42 PM
Pink sludge in bilge Drewboy Newport 5 01-14-2008 09:45 AM
Pink Or White?? Giulietta Off Topic 33 10-18-2007 12:20 PM
