01-24-2012
Thanks to all for the responses!
Originally Posted by RichH
Sure is a problem. Bronze is a mixture of copper and tin ... and with a wee bit of zinc added to aid 'machinability'. When electrolysis begins, and there isn't a proper 'anode' connected the electrical potential will use the zinc in the bronze casting as its anode ... the result is the metal alloy turns 'pink' as the zinc is consumed .. and then the metal becomes 'spongy'.
This is also a warning that possibly that the metal wasnt really a 'true' bronze but rather a 'red brass' with lots of cheap zinc added and the tin content 'reduced'. Lots of asian 'bronze' is actually 'red brass' (zinc loaded 'bronze').
So, the zink on the prop shaft isn't a proper anode?
By "spongy", I assume the consumed Zinc creates voids, and therefore makes the fitting weak?
Other than price (no longer a sure fired indication of quality, now that China has cornered many markets), how can I tell if the replacement is true Bronze?
