My C-22 Project - Page 4 - SailNet Community
 2Likes
post #31 of 43 Old 01-27-2012 Thread Starter
TravelinJack's Avatar
@Bljones - I decided to go with the scrub brush and a bucket of water route after inspecting all the little areas water could find it's way into bad spots. I did use the pressure washer to wash the soap off, but without it actually running. It made for an accurate spray without to much water getting in the boat to have to vac up later. Only did this for the lower portions though. The rest of it I used a crap load of rags and spray cleaner. Thank ya for the link.
T.J.
TravelinJack is offline
post #32 of 43 Old 01-28-2012
JimMcGee's Avatar
T.J. keep postin' pictures!
This time of year these projects are like boat porn for the group
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #33 of 43 Old 01-28-2012 Thread Starter
I certainly will Jim. I know the feeling. I wake up at 6am every morning, but have been staying up until 1am or so going through thread after thread reading comments and articles trying to soak up as much as I can. Then lie in bed for another hour thinking about what to do next. This is seriously cutting into my sleep. But it's worth it, as I've only got another 4 months or so to get finished before I make the move up north to Yankee land. Now if someone would turn on the heater down here I would be eternally grateful.
post #34 of 43 Old 03-31-2012 Thread Starter
Finally back to work
Well, after a bit of a hiatus I'm finally back to work on the boat. Between a heavy work load, getting engaged and my fiance graduating Navy Basic there just wasn't any time. Glad to be making progress though. The picture attached is my buddies boat that he is restoring along side mine here in the hangar. Anyone know what it is???
post #35 of 43 Old 03-31-2012
Re: My C-22 Project
When I bought my c22 it was in really bad shape. Yours times ten with green mung on top of the black spots. I used a solvant called Purple Power it comes in a purple container and it is environmentally safe. Be careful, there is another called the same but not in a purple container and it doesn't perform. The Purple Power cleans everything and you can buy it at Napa Auto Parts.
tom_beckstedt is offline
post #36 of 43 Old 05-21-2013
aka $tingy Sailor
This Old Sailboat's Avatar
Re: My C-22 Project
I just came across this thread and I'm curious about your trailer. I also have a Cat 2 and need to replace my trailer. One similar or identical to yours is available locally. It's an EZ Loader with side rails 15' long. To me, the trailer seems a little too short for the Catalina 22, but it looks like it works for you? Are you able to distribute the weight of your boat properly for towing? How has it worked out for you?
Thanks,
Ken
This Old Sailboat is offline
post #37 of 43 Old 05-21-2013
Re: My C-22 Project
Yes I can distribute the weight . I can drive down the highway 75 mph with no problem didn't even feel like I was towing anything.
post #38 of 43 Old 05-21-2013
Captain Obvious
Sal Paradise's Avatar
Re: My C-22 Project
Thanks,
Ken
His trailer looks pretty much like the one that came with my C22.. works fine.
Here is mine coming home for the first time,
Sal Paradise is online now
post #39 of 43 Old 05-21-2013
aka $tingy Sailor
Re: My C-22 Project
Thanks for the replies, guys.
As one more reality check, if you can look at the attached pictures and confirm back that the trailer looks to be equipped the same, I'd really appreciate it. I've inspected the trailer and it will need a couple hundred dollars worth of new bushings and such but appears solid with only slight surface rust. The tires are 4 years old. I called EZ Loader and they think it will work fine despite not having records back that far.
The next step would be to take my boat and his trailer to the nearest ramp and see how they fit together and what adjustments would need to be made.
Thanks again,
Ken
P.S. Sorry if I hijacked this thread
3E23Ld3F45I85N95Fbd5h8cbaff6d18c11703.jpg   3G73L63I65Na5I45F5d5h3cb6f7e7e06c14df.jpg   3I93Jc3N45L15K35J6d5hca14a5c2c2341fcc.jpg   3L83Ja3H55Lf5E25F3d5h868acf94e09e1549.jpg
post #40 of 43 Old 05-21-2013
Captain Obvious
Re: My C-22 Project
it might work
Look at mine - the keel slides onto that wood beam and it bears a lot of weight.
Our last project bobperry General Discussion (sailing related) 3 12-23-2011 01:44 AM
New project Swb47 Boat Review and Purchase Forum 3 06-24-2010 10:44 AM
Lifeline project jrd22 Gear & Maintenance 3 02-16-2010 02:32 PM
need project near southport, nc closehauled14 Boat Review and Purchase Forum 0 11-26-2009 08:44 AM
I didn't want a project but but I have one slocum2 Gear & Maintenance 3 03-08-2009 08:14 PM
